1970 olds cutlass 350 2bbl th350 vacuum hose diagram
bought the engine it was already pulled from the car, trying to figure out these vacuum hoses, it has the little TCS unit attached on the manifold 2 green wires going to it i found some info on this and it says its supposed to have 3 vac hose connections 1 on each side that go to the front and back of the carb an then 1 that supposed to go to the dist. but it appears thats broken off. atleast one or two vac. ports on the manifold do not have anything attached. and then lastly theres a 3 port vac switch towards the front of the motor the bottom port goes to a T that connects to a port on the manifold the other side of the T i think goes to the th350 modulator, the middle port goes to isn't connected to anything and the top port goes to the dist. i will try to upload pics of everything. if someone has a chassic service manual and maybe can scan a page or too for me i'd really appreciate it as funds are limited right now i cant afford the chassic manual
You don't find the TCS solenoids much anymore so hold onto it. I have that diagram but it is on my home computer. Do search on here I am pretty sure someone posted an image of how those are hooked up. Your description is pretty spot on from what I remember. Does your TCS have the plastic tips still on it or did those break off?
From what I have been told you really don't need it or the three port vacuum advance port either but its nice to have as long as you got them. I beleive one of the ports from the 3 port vacuum switch goes to the TCS I think it Ts to the manifold and the other side goes to the TCS
First of all, join WildAboutCars.com, and you will find your Chassis Service Manual right here.
Second, the attached diagrams should be what you need.
Second, is this motor going in your 84? Do you care about having the Transmission Controlled Spark (an early emissions system) actually working? I suspect not, in which case remove all that stuff and simply run the distributor vacuum advance and the trans modulator off of manifold vacuum. Cap the ports on the carb. Set the timing as needed. Enjoy.
One, please try to use conventional sentence structure and capitalization. Us old farts have a hard time following rambling, run-on questions, and frankly if a question is too hard to understand, I'll frequently blow it off. If you want help, make it easy for other people to understand your question.
I am not certain that a computer that is set up for a 307 with 8:1 compression and a specific cam can run a 350 with 9:1 compression and a different cam well.
You've already got all the parts necessary to make the 350 self sufficient - I'd recommend doing that and saving yourself some trouble. That 2-Jet is a fine carburetor and easy to rebuild.
It will run better without it.
I'm not clear on your rationale for this.
Okay well i'll go with that then, save me some time and hassle. I guess the only reason i was gonna keep the 307 manifold is cause i have emissions testing out here. But if i can find a place that will put a sticker on for cheap enough I'll leave the motor the way it is. Do i need to run a catalytic converter with this motor? Can i run straight pipes? So can you guys give me a quick run down of what i can swap over from the 307 to the 350. What was the hp and torque numbers for this motor back in 1970?
MD will this diagram work on a 77-78 olds 403
Is this motor going in your 84? Do you care about having the Transmission Controlled Spark (an early emissions system) actually working? I suspect not, in which case remove all that stuff and simply run the distributor vacuum advance and the trans modulator off of manifold vacuum. Cap the ports on the carb. Set the timing as needed. Enjoy.
Two questions, though:
1. What do I do with the two green wires running off the TCS solenoid? They are just dangling now.
2. Previous owner had jumpered the connector to the TCS with a resistor. Any idea what function that might have served? Resistor is still in place.
Thanks guys!
I am assuming that the car in question is the '70 Delta in the picture...
Anything you want.
Although I do not have a legible '70 wiring diagram in front of me, I believe I recall that all of them had this resistor.
Without the diagram I can't say exactly why it's there, though.
Anything you want.
cutlass1972s
July 6th, 2010 06:33 PM
