68 Cutlass Fender Emblems
Old Jan 10, 2011 | 06:45 AM
68vaolds's Avatar
How hard are these to remove? Do I have get to the back side of the fender to remove them?
Old Jan 10, 2011 | 06:59 AM
Aron Nance's Avatar
68vaolds: Yep, you do have to go inside to get to the fender script. Can be done, but also can be very tedious. Hope you have small hands, small wrenches, and a good bit of patience. Good Luck!
Old Jan 10, 2011 | 07:18 AM
68vaolds's Avatar
What is the best way to do that?
Old Jan 10, 2011 | 07:22 AM
Remove the front fenders. If you're lucky and have small hands, you might be able to remove the bottom bolts holding the fender to the cowl without spinning the clip nuts. This will allow you to reach up behind the fender and remove the nuts.
Old Jan 10, 2011 | 07:23 AM
Aron Nance's Avatar
If memory serves me correctly (and it may, or may not; gettin' older. LOL!) You can remove the fender well and fender - or - open the door about 1/2 way, and with a flashlight look into where the backside of the emblem would be. You should see the "prongs" and the "speed nuts" that hold the emblem on to the fender. That's where the "small", be it tools or hands, comes in. Once again, good luck. Not an easy thing to do.
Old Jan 10, 2011 | 09:12 AM
You can certainly SEE the nuts with the door open. Whether or not you can reach them is a different question. I know I've never been able to get them off that way.
Old Jan 10, 2011 | 09:15 AM
rcorrigan5's Avatar
Randy C.
I was able to loosen the inner fender enough to get my hands between it and the fender to remove the speed nuts off the back of the emblems. It'll put a healthy crease in your lower forearm!
Randy C.
Old Jan 10, 2011 | 09:42 AM
oldsguybry's Avatar
NOVICE car nut
Randy C.
yep, thats how I did it , since I had to find a way to stop the nut from spinning in order to get the bottom part of the fender loose. I ended up taking the plastic wheel well off first , so I figured I may as well get the emblem off while im at it.....ripped my forearms up.
70Post
Dec 31, 2015 11:35 AM
JCMC64
Mar 18, 2014 05:59 AM
oldzzy
Dec 9, 2011 09:12 AM
Rusty Boltz
Oct 4, 2011 09:51 AM
67CutlassGE
May 24, 2011 09:18 AM
