Am I right on the rear gear that it is a 3.08
Old May 5, 2025 | 12:52 PM
azmusclecar's Avatar
Im going to look at a 1969 442 WITH AC........and I'm trying to know what I'm looking for. It is a 4 speed. Any correct info is appreciated
Old May 5, 2025 | 02:47 PM
rcorrigan5's Avatar
Randy C.
If I'm reading correctly, the standard differential for a '69 4-4-2 with A/C is 3.23:1, which is what my '69 4-4-2 convertible with A/C has. The standard differential for a '69 4-4-2 with the THM 400 transmission is 3.08:1.
Randy C.
Old May 5, 2025 | 05:39 PM
Thanks Randy, are those specs from AUTOMATICS? This 442 is a 4 speed manual with A/C.........that is the oem rear gear im trying to find.
Old May 5, 2025 | 06:29 PM
rcorrigan5's Avatar
Randy C.
Yes, 3.23:1 is standard for a '69 4-4-2 with A/C and the wide ratio 4-spd transmission. It looks like 3.08:1 was an optional differential. As well, anti-spin (G80) was also an option.
Randy C.
Old May 6, 2025 | 05:46 AM
Randy is correct. Base equipment ratio with M20 four speed was 3.42 without A/C and 3.23 with A/C. The 3.08 ratio was optionally available on four speed cars. From the SPECS booklet. Footnote b denotes standard with A/C.
Old May 8, 2025 | 03:07 AM
Thank for the input on the gear situation. I can live with 3:23 on these Interstates. To get to most car shows and cruises I will need to use the
Interstate system and i like using the tool of calculating the rpms when adding in circumference, speed, gear ratio and coming up with the engine rpms.
I had a 3.08 gear in a 1964 Corvette with the M20 and it was nice on the Interstate. 3;23 won't be that much difference. Once again thanks to all for
the wealth of info.
Here's a link to the tool I use for calculations. Thought maybe someone else could use it someday.
https://purperformance.com/p-29669-rpm-calculator.html
Old May 8, 2025 | 08:52 AM
rcorrigan5's Avatar
Randy C.
Are you sure the car you are going to see has a 3.23? It could have the optional 3.08. It may be worth at least checking the code on the axle to make sure. The code will vary based on where the car was built, whether or not it has the disc brake option, and whether or not it has the anti-spin axle option. The code will appear as either two letters or a letter and a number and usually found upside down on the front of the passenger side axle housing.
Randy C.
Old May 8, 2025 | 08:54 AM
^^^THIS. The fact that 3.23 was the standard gear doesn't mean that an optional one wasn't ordered.
Hinkley70
Drivetrain/Differentials
Mar 2, 2020 12:17 PM
David DeCan
26
Jan 30, 2016 11:15 PM
beebee78
Jan 1, 2012 11:05 AM
Seff
Nov 2, 2011 05:30 AM
AZ442
Oct 31, 2009 05:06 PM
