Hei timing advice
Old Jan 22, 2022 | 04:55 PM
abody's Avatar
Hei timing advice
Just put a had an HEI from jegs put in my 70 cutlass, it runs good, same as before, what would the timing be best set at? Feels a little less powerful, Had it put in while my trans was getting rebuilt.
Old Jan 22, 2022 | 06:14 PM
shiftbyear's Avatar
Your engine has it's own requirement for timing, HEI's can have excessive mechanical advance so check total at 3500-4000. I'd start of with 12 degrees initial and limit total to 36 with vacuum advance plugged. If your changed from points to HEI it may require a spark plug change or regap. Vacuum gauges are also good to have while tuning.
Old Jan 22, 2022 | 07:04 PM
Which HEI are you running, brand and model#?
Old Jan 22, 2022 | 09:04 PM
As said above, the mechanical advance on the electronic distributor may be less than the points distributor. If so, the initial advance may need to be increased from the points spec to achieve the same total. This will vary with different distributors, so knowing which one you have will help us give recommendations.
As for plug type and gap, no requirement to change anything. I open the gap slightly to .045” but that is not mandatory, it will work fine at .035”
Old Jan 23, 2022 | 07:38 AM
abody's Avatar
Here’s the one I had put in
Here’s the one I had put in from jegs
Old Jan 23, 2022 | 07:39 AM
abody's Avatar
Part Number: 555-40028 For the distributor
Old Jan 23, 2022 | 07:41 AM
abody's Avatar
The car is all stock except for 2.5 exhaust with an H pipe.
Old Jan 23, 2022 | 07:43 AM
On that HEI, it should have around 21* of mechanical advance. You can set your timing @16-18* and then limit your vacuum advance with a stop to 10.
Old Jan 23, 2022 | 08:16 AM
Your factory points distributor had 24* mechanical advance, so set to 10* initial per spec gave 34* total. You should be able to get the new distributor set close to that.
If your points distributor was working properly, don't expect to see any difference in operation/performance with the HEI distributor. The spark plugs will fire just the same as before, so the engine won't be able to tell any difference.
Old Jan 23, 2022 | 11:26 AM
abody's Avatar
Thanks, I appreciate the advice
Old Jan 23, 2022 | 11:29 AM
coppercutlass's Avatar
Chevy budget Olds powered
Fwiw on my 350 I run 14 initial total 36 around 2k. Of course my 350 is more of a race car I drive on the street and race as well at the track but that's what works for me. Guys always say to run a bunch of initial but I beg to differ.
Gone Johnson
Nov 21, 2021 10:14 AM
drjr56
Apr 19, 2020 05:24 PM
truckman5000
Oct 1, 2017 02:02 PM
FAZ442
Apr 29, 2012 11:48 AM
1973olds98
Oct 29, 2010 09:35 PM
