Speedo/Dash Lights
Speedo/Dash Lights
I have a speedo light that's out. All of the rest of the lights in the dash are working, with the exception of the speedo. I was just curious on how and to what extent is the difficulty of replacing the bulb for the speedo gauge?
A second question that I had about that dash light was on the heat/AC control unit, my dashboard only lights up the fan speed (right side) of the heat/AC control until. I was just checking to see if the left side which controls temp and where the air comes out of is supposed to light up as well. Seems odd that only half would light up. If that light is as well, what's the process and difficulty of replacing that. Hopefully not looking to pull the entire dash to replace one or two bulbs.
Thanks in advance.
Thanks in advance.
