1970 Cutlass Starter Question
Old Oct 3, 2017 | 03:56 PM
dejay99's Avatar
I need to replace the starter in my 1970 Cutlass Supreme with 350V8 and 4bbl soon. Suppliers are listing two replacements, on with a spacer and one without. Which is the correct one? Thanks for your help.
Old Oct 3, 2017 | 04:05 PM
Do you have a link as to what your looking at?
Old Oct 3, 2017 | 05:18 PM
RetroRanger's Avatar
72 Olds CS
I would opt for the ac delco unit if it were me
Old Oct 3, 2017 | 05:23 PM
If I remember correctly , the starter with the 1" spacer is the high torque version.
Old Oct 3, 2017 | 06:23 PM
dejay99's Avatar
Rock Auto lists REMY #25253 and #25275 as replacements. The #25253 has a copper spacer.
Old Oct 3, 2017 | 06:30 PM
dejay99's Avatar
Rock Auto is only showing two REMY starters now on their website.
Old Oct 3, 2017 | 08:31 PM
72 Olds CS
might depend on what you hit for a car i used a 1970 cutlass, but they may list different for a supreme or delta i also saw they had a 442 listing w a 350(for 1970) . AFAIK the starter is the same for all 350s except maybe the toro !!
anyway i dont know what the spacer is but i would double check the selection by going to another site like auto zone or advanceauto etc...
IDK what remy is but i still lean toward the delco part.
Old Oct 3, 2017 | 09:36 PM
dejay99's Avatar
Thanks for your help. I'll do a little more checking.
Old Oct 4, 2017 | 05:48 AM
^^^THIS!
Either one will work on a 350 motor. The one with the spacer is a high torque version.
Old Oct 4, 2017 | 06:49 AM
My442's Avatar
Go with the high torque version.
It gives you a little more capacity to start the car.
Old Oct 4, 2017 | 02:51 PM
dejay99's Avatar
OK, thanks for your help
Dan K
Jul 24, 2017 09:20 AM
joesw31
Jan 16, 2017 11:21 AM
Supreme455
Sep 24, 2015 10:22 PM
roberer
Sep 22, 2015 09:36 AM
pcard
Aug 22, 2015 06:49 PM
