Windshield trim
Old May 25, 2014 | 02:58 PM
Double D Farms's Avatar
Windshield trim
I have some missing parts on the '69 Cutlass S convertible that I'm rebuilding. It's been a long time since we disassembled it, I need some input. 1st, concerning the lower windshield molding. Is there a seal between it & the windshield or does it take some sealant? When I tighten the screws that hold it, the top of it raises up from the windshield. Also on the interior trim molding at the top of the windshield I know there are 3 screws that hold it to the top of the windshield frame, but on the bottom side there are 3 holes that line up with 3 bigger holes on the frame. I was thinking that there may have been a fastener that sits behind the frame that the lower screws go to? Any help is appreciated.
Thanks, Mike
Old May 26, 2014 | 10:38 AM
2blu442's Avatar
Mike, if your talking the wide stainless piece at the bottom of the windshield it should lay flat and tight against the glass when the fasteners are tightened. There's no sealant under it. Is this the same one you removed before the restoration? Could it have gotten bent?
John
Old May 26, 2014 | 08:03 PM
No, its a troop. The original didn't come back from the 1st painter. I guess I will have to try to bend Ur to fit.
Old May 26, 2014 | 08:04 PM
No, its a repop. The original didn't come back from the 1st painter. I guess I will have to try to bend Ur to fit.
Old May 26, 2014 | 08:21 PM
69442murph's Avatar
if you can see the brackets on the inside of the trim that keeps it mounted properly....all 6 screws should be the same thread size unless the holes have been drilled larger...
got to love the re-pop stuff...nothing like gm...
Oldssupreme
May 28, 2013 05:35 PM
StarGeneral
Jan 29, 2013 06:52 PM
oldspackrat
Jan 31, 2012 10:59 AM
StarGeneral
Body work
Dec 1, 2011 07:32 PM
curtman02
Dec 26, 2007 07:34 AM
