Turn Signal Problem
Old Aug 10, 2013 | 08:29 PM
  #41
starfire's Avatar
I host mine at Photobucket and link them here.
Old Aug 10, 2013 | 08:35 PM
  #42
87oldscutty's Avatar
Ok thanks
Old Aug 11, 2013 | 08:57 AM
  #43
starfire's Avatar
Most likely reason your reflector has a bulb in it is that someone replaced the reflector with a marker light from an '81-86 Cutlass. They had marker lights there:
With the eurostyle front end in '87 - '88 the marker light was moved up to next to the headlight. You can just ignore that bulb (or just take it out).
Old Aug 11, 2013 | 09:04 AM
  #44
starfire's Avatar
Blue arrow points to where your marker light lamp should be. It should have two wires coming in from the harness ending in a rubber bulb holder. One of the wires is power, the other ground.
I replaced my burned out bulb this morning, that is what it should look like out of the socket.
Old Aug 11, 2013 | 02:36 PM
  #45
This is the light I am talking about. I also tried to upload a video to youtube about the alternator. I checked it and it was putting out 12.6 to 12.7 volts to the battery.
Old Aug 11, 2013 | 03:13 PM
  #46
starfire's Avatar
No, there should be no outside screws and it should be amber in color. You will need to find one off of a parts car. Put a parts wanted ad on this site or look through the parts for sale area for someone parting a car.
Should look like this:
Looks like they cut your trim strips (mine are chrome 'cause it's a 442) to put the taller "light" in. That sucks too. I don't know if they are repopped. You may be able to get them from someone's parts car too.
Your alternator is not functioning properly. Should be putting out at least 13.7 volts. Take it off and take it into an auto parts store. They should be able to test it (and sell you a new one when it fails). Sorry.
Old Aug 11, 2013 | 03:16 PM
  #47
That is the same light that Alan told you is not the sidemarker.
Stop messing with it.
That is too low. Houston, you have a problem.
This could be the cause of all of the things that you listed.
You need to find out why - bad connection or bad alternator.
Start by cleaning all of the connections, or, as Alan suggested, take the alternator to be tested..
Old Aug 11, 2013 | 03:20 PM
  #48
when I start the car or take the negative terminal off the battery the alternator/belt is quiet but after I run it a few minutes (with battery terminal connected) it makes a squealing noise. I felt the belt and it feels tight but I wonder what the deal is there too. The guy I got it from said the alternator was new but there is NO way it is new lol
Old Aug 11, 2013 | 03:53 PM
  #49
If your belt is slipping, that will reduce charging, too, but usually it's not an issue at idle, when the alternator isn't providing much resistance to rotation anyway.
Old Aug 11, 2013 | 03:56 PM
  #50
so my belt could be the problem? I am working on getting a video on youtube so you can hear the noise. I really do appreciate all your help guys.
Old Aug 11, 2013 | 06:28 PM
  #51
starfire's Avatar
Is the belt tight when the engine is warm? The belt may be tight when cold, but loosen up after it gets warm.
I'd still take the alt in and get it tested. I've had bad one's right out of the box. They test them for free.
Old Aug 11, 2013 | 06:58 PM
  #52
I should have the video up and running soon. YouTube is being very slow tonight.
Old Aug 11, 2013 | 07:14 PM
  #53
Tim Gilliam's Avatar
I just fixed this exact same problem. I ended up taking a 4gauge stranded wire and putting a lug on one end and polting it to the block using an Exhaust manifold bolt, I then laced it over and attached it to the fender. Everything works like a champ now.
Old Aug 11, 2013 | 07:37 PM
  #54
this is the video I have been trying to get uploaded.
Old Aug 11, 2013 | 08:25 PM
  #55
So,
1. You had to have a battery charger on it to get it to crank. Subtle sign of a problem.
2. Voltage too low, but I would be interested in knowing whether it goes up when you rev it to 1200 RPM.
3. What happened to make the squeal start the first time?
4. It looks like you got the same voltage from the (+) battery terminal and from the (+) alternator post - Is that correct?
5. Your belt is too loose and it's slipping. Tighten it, and let us know whether the voltage goes higher (and what it goes to).
6. When you disconnect the battery, the squealing stops, because the alternator is trying to charge that poor battery.
Give the battery a full charge, for Heaven's sake.
7. What voltage does the alternator make when the battery is disconnected?
This is not a valid or accepted test, but, since you are disconnecting the battery with the engine running anyway, why not see what the voltage is on the battery terminals (the wire ends, not the battery itself) when you do it?
Oh, and those front bumper sidemarkers are a total abomination.
Good luck.
Old Aug 11, 2013 | 08:31 PM
  #56
I put it on a trickle charge while I was at work to make sure the battery was charged when I got home from work. I think the side marker lights are horrible too. The belt was squealing like that when I got the care. I am gonna pick up a new belt tomorrow. I think they are like $5 at the autoparts store so why not lol. I am going to put it on a charge tomorrow and not mess with it for a few hours. I will say that when I shut the car off the battery was holding a charge of 12.74 volts without any dropping off. I will check the alternator the way you say to as well.
Old Aug 12, 2013 | 12:02 AM
  #57
Its 3:00 am in Ohio and I just went out to check my alternator belt and I can grab the belt and squeeze it where it will almost touch itself. That tells me the belt is loose haha
Old Aug 12, 2013 | 04:39 PM
  #58
starfire's Avatar
7 hours prior to this you said the belt was tight
Old Aug 12, 2013 | 06:28 PM
  #59
You can't believe everything you read on the internet.
Really.
Old Aug 16, 2013 | 01:23 PM
  #60
Well I put a new belt on it that didn't solve anything with my alternator. I am still getting 12.5 to 12.7 volts. I thought the belt was loose. I guess my alternator is crapping outl
Old Aug 16, 2013 | 07:37 PM
  #61
If what you said here is true:
... I can grab the belt and squeeze it where it will almost touch itself.
Then the belt was loose.
costpenn
Jun 24, 2015 10:38 PM
Mr Nick
May 27, 2015 11:06 AM
luther
Sep 29, 2007 10:41 PM
jk121
May 14, 2007 01:49 PM
js_specials
Aug 18, 2006 10:31 AM
