Transmission wire question
Old Oct 3, 2015 | 07:39 AM
Bennettre46's Avatar
1968 Olds Cultass S 350
According to my parts store I have a Super Turbine 300 2 speed transmission. in my 68 Cutlass. According to an assemblly manual it appears to be a "Jetaway" transmission. I believe the 2 are 1 in the same.
My issue is it looks like the wire that goes down to the transmission has the metal ear in it that should still be on the trsnsmission. It looks like the msanual is caslling that the kickdown actuator? Correct? What is the best way to repair/replace the wire connection in the transmission?
I cannot even get a filter kit through NAPA for this transmission only a complete rebuild kit. Please let me know what you guys know for a fix and any place to get parts. Thanks.
Old Oct 3, 2015 | 08:09 AM
They are one in the same. I don't know where the kickdown switch is for your model year, but it needs 12v at the trans to down shift. The filter should be readily available over the counter.
Old Oct 3, 2015 | 09:55 AM
TripDeuces's Avatar
To replace the connector in the transmission you have to drop the pan and gently bend the tabs from the back and push it out. Considering it's age and has been exposed to the hot transmission fluid it will probably be pretty brittle so be careful. Getting a new one might be a good idea and then you can replace it when you do the filter.
Old Oct 3, 2015 | 08:31 PM
Parts for the ST300
Any idea where to buy a new electrical plug for one of these? The one in the transmission.
Old Oct 3, 2015 | 09:18 PM
Try a transmission shop. They may have some cores and just give the part to you.
Old Oct 4, 2015 | 08:26 AM
"Jetaway" was the brand name Olds used for the ST300 two speed trans. It is NOT a Powerglide, despite what some people may tell you. The plastic trans connector should be the same as the one used on the TH400 trans. Those are available everywhere. Fatsco is a good source for filters, gaskets, and parts. The kickdown switch is on the accelerator pedal, under the dash, just like on all 1968-72 A-body cars.
Old Oct 4, 2015 | 02:01 PM
Same as turbo 400
That's great to know Joe. Thank you.
superstingray77
Jun 27, 2011 06:13 AM
Joel
Apr 12, 2011 02:58 AM
68cutlassdriver
Mar 6, 2011 11:53 AM
tarheeldoc
Jun 3, 2009 06:42 AM
Furr442
Mar 24, 2008 05:04 AM
