Tire size
Tire size
Can someone tell me the stock tire size on a 1965 Cutlass convertible. I looked in both the owners manual and the shop manual and can't find the size in either one. I am thinking it was either 750 x 14 or 775 x 14. At present it has bfg 205-70r14 but I think they somewhat smaller than original.
I don't really know anything about this topic, but I did find a few online sources that indicate the standard equipment tire size was a 7.35x14. I didn't do an exhaustive search, but I also didn't find a source that lists a different standard equipment tire size.
To expand on the above, the 7.35x14 was standard, but 7.75x14 was optionally available, per the SPECS booklet:
This table provides dimensional information:
The 7.35x14 had an OD of just under 26" and a section width of 7.3". As noted above, 205/75-14 is the closest available modern tire, though about 3/4" wider in section. The optional 7.75x14 had an OD of 26.7" and a 7.75" section width. 225/70-14 is the closest available modern tire; slightly smaller in OD and about an inch wider in section.
Thanks for your help Joe & Hurst. and thanks for posting the list of standard equipment, very interesting. My 205/70R14's only have an effective diameter of 23 1/2" (11 3/4" center to floor) even though the diameter is listed as 25.3. I know my speedo reads about 10% or more fast.
I've got nearly new BFG Radial ta's that were put on shortly before I purchased the car, so I guess I'll stay with them for now. I do wish they were a couple of sizes bigger as rpm at 70mph is close to 3400rpm with my 3.23 gears.
Yeah, between torque converter slippage and tire rolling radius effects, that's somewhat higher than the theoretical 3000 RPM at 70.
