Tips on 72 rear end
Tips on 72 rear end
Hello everyone,
Im getting ready to start working on my 72 after a pretty busy year. Its a 72 cutlass convertible with a 455 and auto transmission.
My plan was to put in a posi in and change the gears to give it a little more get up and go around town.
I wanted to know if you guys could recommend where I can get the parts and specifically what parts I should get. I don't have a good junk yard nearby and I would prefer to buy the parts new anyways. I believe I have a 12 bolt rear end and a 3 speed transmission. How much would all of this set me back?
The transmission shifts very smoothly but since I have to drop it to work on the rear end would it be smart to have it rebuilt since its out?
Sorry if some of these questions sound amateurish. This is just a hobby of mine and my neighbor does the majority of the work.
Thank you for your advice in advance.
Hello everyone,
You probably have a Corporate 10 bolt if the car is stock. Not a 12 bolt.
Figure a couple hundred bucks for the gears (depends what you buy) and a couple hundred for the posi unit (depends what you buy). Check Summit Racing equipment...you might consider just having a shop do this if you're not going to do it yourself.
You don't have to take the transmission out to work on the rear end...so...no.
Feel free to add something constructive to the thread...or don't. Your call.
Damn it's good to be back ain't it?
My apologies...why don't you look up the exact dollar amount and give the guy a more accurate assessment of the situation he's in rather than come on here waiving your purse around?
If you are correct that is great. Share the source. If you gave false or incomplete info then maybe it is YOU who needs to be more constructive with you posts.
I don't have a purse but I am ok with it if you do. I won't judge you.
GreekDog,
If your car has the original rear end it should have 10 bolts on the cover & 10 bolts holding the ring gear to the carrier. If you can take a good clear picture of the cover we can help you identify what you have. The good news is that it is a good rear end as is & is pretty easy to find parts for. There are a couple great rear end guys on this board that will probably chime in soon to guide you in the right direction.
To play Devils advocate my buddy paid 400 for a Yukon posi unit from an eBay vendor. I installed it and a 3.90 gear in an 8.5 .,he spent Bout 850 all said and done and I installed it all for free. I just had my posi unit rebuilt with a 12 bolt style clutch and a few other tricks and a used 3.90 gear and spent 700. I decided to have mine rebuilt by a good friend because of preference, my usage and his experience with high hp diffs, but to be honest if I bought a new posi and new gear I would have spent the same had I built it my self but I have my reasons. Any who that's some food for thought.
Please check your hate & anger before you post in the future; it's embarrassing for you.
I've been looking, unless you are going all used parts, no way its happening for a couple hundred..
On jegs today,
auburn electric is $842
detroit locker $735
auburn Pro series $531
eaton $509
Yukon gear $476
auburn $424
even a lunchbox locker is $350
easy hundred for bearings/shims
gears are $275 and up..
and put it all into a 45 year old housing and axles.
On jegs today,
detroit locker $735
eaton $509
Yukon gear $476
auburn $424
You can likely get a used limited slip differential for a reasonable price. I would have no issues using one as it would probably be in the same condition as the original in my car, which still works fine.
The Richmond Gear web site listing for vehicles that used the 8.5" 10 bolt is a good reference for what vehicles to look for in a salvage yard or other sources for used auto parts. I think the carrier you would want is the 410408 casting as it is the "3 series carrier" and will work with ratios of 2.73-up. The 410409 carrier was used with 2.56 and 2.41 ratios.
EBay but caveat emptor http://www.ebay.com/itm/GM-8-5-Posi-...5VekWq&vxp=mtr
bumblebee72
July 28th, 2015 12:33 PM
350TurBRO
September 12th, 2014 11:52 AM
