Timing Plate Missing? 70 Cutlass S
If it's missing, it's because someone removed it. Your only option is learn to live with it.
Of course, the skeptic in my would be worried that the cowl tag might have been removed because the 336xxx cowl tag didn't match the "new" 344xxx VIN tag.
Data plate or timing tab? Data plate, or cowl tag as it is sometimes called, is located on the firewall drivers side upper area. The timing tab, is at your crank, and is used for the timing of the engine.
1969 and Joe: Yeah I meant the timing tab, it's gone! For a example of what I mean, in the picture below it has neither of the tabs, not just the one pointed at with the arrow. Anyone know where I can buy the tab or does anyone know how to check the timing without the tab?
http://www.musclecars.net/parts/68-6...154847569.html
And to avoid the comments (
), yes, it won't work with a 1964 balancer and water pump, and yes, it's not the same as the later plastic tabs, but it WILL bolt to any Olds block.
Maccabeus
Dec 29, 2007 09:13 AM
