Tail light help
Old May 20, 2008 | 04:22 PM
woody367's Avatar
Tail light help
Does anyone know a good sorce for replacement tail light assenblies? I am looking for the complete houseing and lenses. I have been looking but no luck. I have a 72 cutlass supreme. Thank
Old May 20, 2008 | 05:02 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
I have a set of 71's if you don't care about correctness. $50 shipped to you.
Or if you want a set of brand new correct ones, go to fusick.com and look on page 18 of their catalog.
Old May 20, 2008 | 06:58 PM
woody367's Avatar
Thanks, thats the lenes. I also foung the at YEARONE. Where can I get newhousings with the sockets. This is for a friends xar. Hiswiringin the sockets areall corroded. From what it looks like its is all one peice or can just the harness with the sockets be replaces and if so where can it be gotten?
Old May 20, 2008 | 09:35 PM
You can get the sockets at dormanproducts.com probably.
Old May 31, 2008 | 07:17 PM
Chumley's Avatar
Once in awhile I see tail light assemblies on ebay that look pretty good.
Chumley
Old Jun 1, 2008 | 09:19 AM
What's wrong with your housings, exactly? The sockets are swaged into the housings and are difficult to replace correctly. Your best bet is to clean up your original housings and sockets if possible. If you do look for replacements, the 71 and 72 housings are the same. Only the outer lenses are different.
Old Jun 28, 2008 | 09:34 PM
southcarolina803's Avatar
71'OldsCutty
Tail lights
DO you still have the tail lights?
Old Jul 9, 2008 | 06:47 PM
If you just want replacement taillights, check ebay (aka evilbay). There's always someone who has either the lenses, or a complete taillight setup c/w harness and fittings.
Parts Place, Fusicks and Year One have the rear tail light harnesses pre made, just plug and play(so to speak). If the tail light buckets are shot, it's probably because the lense gasket failed or wasn't installed, OR the rock guards that protect the buckets on the back side are missing / damaged.
Good luck with your quest.
Allan R
carnell71075
Apr 12, 2015 04:09 PM
andrewk94
Dec 9, 2014 12:17 AM
jensenracing77
Dec 11, 2013 08:22 AM
5998DownUnder
Ninety-Eight
Apr 19, 2013 05:56 PM
64starfire
Apr 6, 2011 09:07 AM
