Tail light help
Thanks, thats the lenes. I also foung the at YEARONE. Where can I get newhousings with the sockets. This is for a friends xar. Hiswiringin the sockets areall corroded. From what it looks like its is all one peice or can just the harness with the sockets be replaces and if so where can it be gotten?
What's wrong with your housings, exactly? The sockets are swaged into the housings and are difficult to replace correctly. Your best bet is to clean up your original housings and sockets if possible. If you do look for replacements, the 71 and 72 housings are the same. Only the outer lenses are different.
If you just want replacement taillights, check ebay (aka evilbay). There's always someone who has either the lenses, or a complete taillight setup c/w harness and fittings.
Parts Place, Fusicks and Year One have the rear tail light harnesses pre made, just plug and play(so to speak). If the tail light buckets are shot, it's probably because the lense gasket failed or wasn't installed, OR the rock guards that protect the buckets on the back side are missing / damaged.
Good luck with your quest.
Allan R
Allan R
jensenracing77
Dec 11, 2013 08:22 AM
