Tach needle stuck
Old Feb 4, 2017 | 07:29 AM
Timmygun1's Avatar
Tach needle stuck
My tach works just stays red lined any idea as to make it work properly. 1971 olds 442 rally pack tach the clock does not work. Thanks
Old Feb 4, 2017 | 09:10 AM
z11375ss's Avatar
Senior Moment Member
Take your foot off the gas.
Old Feb 4, 2017 | 09:11 AM
z11375ss's Avatar
JK. Sounds like a disassembly time.
Old Feb 4, 2017 | 09:15 AM
Originally Posted by Timmygun1
My tach works just stays red lined...
I'm not sure that this would qualify as "works" in most people's dictionaries.
Could you describe its actual behavior?
Old Feb 4, 2017 | 09:19 AM
texxas's Avatar
Works but is stuck at redline? Is this like all those cars listed for sale that say the air conditioner works but JUST needs a charge?
If it is stuck at redline how is it working? I'm not trying to be a wise ***, I really am confused. Is the needle loose from the pin? How do you know it is working?
Old Feb 4, 2017 | 09:53 AM
RandyS's Avatar
Did it ever work correctly for you?
Old Feb 4, 2017 | 10:52 AM
svnt442's Avatar
Does the needle go back to 0 when you shut the engine off, or does it just stay put at redline?
Old Feb 5, 2017 | 03:58 AM
Timmygun1's Avatar
OK here is a better explanation. The tach works. It goes to zero. When you start the car it goes to recline that is its idle point. If my car idled at Red line it would be awesome. I've heard there is an adjustment on the back of the tach. This is an original 455 w30 car point distributor. Any real help would be welcome.
Old Feb 5, 2017 | 11:08 AM
Del70's Avatar
I think the adjustment feature was not intended to correct an "issue" , but was used at the mfg of the gauge to fine tune it. If it were mine, I would check the connections at the back and at the coil etc and work thru the issue. Based on your note, sounds like both the tack and clock functioned as intended before, and now the clock is not working, and the tack reads at max with the engine running..Again I would start start with checking connections...
Old Feb 5, 2017 | 02:31 PM
Timmygun1's Avatar
Thank you Del70 I was thinking the same thing. It may be a ground problem. I will pull the dash head tomorow. Thanks for your response!! Have a,great night!
RAMBOW
May 3, 2022 04:25 PM
hinz57
Aug 4, 2019 02:33 AM
OldSchoolMuscle71
Aug 29, 2012 02:45 PM
stevengerard
May 7, 2010 11:00 AM
My442
Jan 2, 2010 04:57 PM
