Starter ?
Old Jan 25, 2009 | 03:25 PM
veltboy618's Avatar
Starter ?
How can i get the gear in the sterter to come out without the gear spinning? It's a SBC starter.
Something like this
Old Jan 25, 2009 | 04:13 PM
Since it is a SBC starter you could probably take a pair of needle nose pliers and bend the starter gear shaft sideways so you can take the starter off the engine. Don't worry, once you get the starter on the bench you can bend it back into place and it should work fine. Chevys are pretty tolerant. Since Chevy parts are made of Chinesiumit it won't require gorilla strength to bend.
Old Jan 25, 2009 | 06:56 PM
Oldsguy's Avatar
Past Administrator
Man, that picture looks backwards or something. Is that on a chevy?
Old Jan 26, 2009 | 04:03 AM
Something like this
Is it a Delco factory starter or a mini starter? On the Delco, you can temporarily unbolt the lower stud on the solenoid (the one that goes to the starter winding) and the solenoid will kick out without turning the motor. There are several different versions of ministarters and I'm not sure how to do it on those.
cutlassKing
Mar 30, 2007 01:06 AM
bjtstarfire
Dec 3, 2006 02:38 PM
jerry d
Apr 18, 2006 05:05 AM
Bens71442
Jan 3, 2006 03:33 PM
Lobo
Jun 29, 2004 09:05 PM
