SSIII rims
Old Jul 22, 2009 | 07:48 AM
tdubis's Avatar
SSIII rims
Morning- I am picking up a complete set of 5 1969 oldsmobile SSIII wheels today and I assume they will fit my 71' Supreme....hate to assume
so I ask. Is this correct, do not want to shell out $150 for nothing.
Thanks, Tom
Old Jul 22, 2009 | 07:53 AM
An SSIII is nothing but a SSII painted the body color as oppossed to argent silver[grey]
69 were SSII painted argent
Without writing a tome about the subject. "Basically" there are two types bolt on centers and snap on centers. 14" and 15" The bolt on being earlier and more desirable.
Sounds like a bargin and yes they should fit.
Old Jul 22, 2009 | 09:44 AM
Are you sure they are from a 69 Olds? They could be the later SS wheels that came on the B body. If so they might not fit your vehicle. Just measure the bolt circle to make sure before you buy them.
Old Jul 22, 2009 | 10:23 AM
tdubis's Avatar
69' Olds for sure, Going to pick up this afternoon. Thanks
for the replies!!
Old Jul 22, 2009 | 06:46 PM
All SSII/III wheels came with the 5 x 4.75" bolt circle.
Old Jul 23, 2009 | 02:11 AM
jensenracing77's Avatar
i never knew that the B body cars ever had this wheel design.
Old Jul 23, 2009 | 05:47 AM
Oh ok. I guess the reasone I got confused is that the older B/C bodies had a 5 x 5" bolt circle. I know for a fact that Oldsguy had to use adapters to fit SS wheels on his 69 Delta 88.
https://classicoldsmobile.com/forums...to.php/photo/5
Old Jul 23, 2009 | 09:30 AM
Yes, they were offered on the 77-85 Delta 88s. These "downsized" full size cars were available with either the A-body 4.75" bolt circle or the 5" bolt circle when fitted with the HD brakes. Obviously the SSII/III wheels were only offered with the smaller brakes and bolt pattern. The 77 D88 Indy Pace Car used them. These full-size applications typically used the snap-in "starfish" wheel centers.
Old Jul 23, 2009 | 09:47 AM
That was an awsome car. Oldsguy and I found a 78 Holiday 88 in the wrecking yard one time that was blue with T-tops and a console shifter. That was an awsome car. I didn't have the engine, transmission, or wheels anymore though. It probably had a 403.
anthonyP
May 25, 2014 09:18 AM
InTheCutt
Wheels and Tires
Feb 27, 2013 09:42 AM
oldzy
Wheels and Tires
Dec 7, 2011 01:58 PM
Pghstarsky
May 28, 2008 03:17 PM
