Shocks
Old Apr 13, 2014 | 04:54 PM
luddie's Avatar
Shocks
I recently installed station wagon springs on my 1969 Cutlass convertible, now my air shocks don't have enough stroke. Does anyone know if there's a rear shock with a 21" or more extended length that will bolt on?
Old Apr 13, 2014 | 05:10 PM
RandyS's Avatar
You can also drill a hole closer to the top of the mounting plate to give you a higher mounting position if you only need a few inches. (no pun intended...)
Old Apr 13, 2014 | 05:32 PM
jag1886's Avatar
Go to your parts store and pray they have a real parts manual "as in paper book". In the back of the parts manuals they list all the lengths and type of ends that are on the shocks. You might also be able to find this on line with a little searching.
Old Apr 13, 2014 | 05:53 PM
JPMDaddy's Avatar
none of the guys at Autozone, O'Reilly's or NAPA in my area would know how to use that kind of parts books
Old Apr 14, 2014 | 01:36 PM
luddie's Avatar
Has anyone ever used shock extenders??? Do you think they will work for this situation? I found 3" extenders on ebay.
Old Apr 14, 2014 | 01:54 PM
RetroRanger's Avatar
72 Olds CS
maybe goto some manufacturuers web sites to find length stroke and end info
KYB or Edelbrock or bilstein are good brands
Old Apr 14, 2014 | 02:15 PM
You also have to take into consideration that they will settle a bit over time. You can call any shock manufacturers tech line and they can recommend a part number to you.
Old Apr 14, 2014 | 06:28 PM
69 Ragtop's Avatar
I used them years ago. In your case, I don't see why they wouldn't work. O'reilly's has them for $11.99
http://www.oreillyauto.com/site/c/de...0146&ppt=C0361
Old Apr 17, 2014 | 05:19 PM
White_Knuckles's Avatar
I may be off but was hoping adding wagon springs would lift my car (to level) where I could get rid off the air-shocks and run conventional gas shocks? I yanked the air-shocks out on an El Camino years back and matched up slightly taller/stiffer moog springs with S-10 Blazer rear shocks. The combo worked well.
Why will you need to run air-shocks with the new springs?
Old Apr 24, 2014 | 02:35 PM
luddie's Avatar
I really don't need the air shocks. I'm going to change them to gas shocks, the ride will be way better!
Old Apr 30, 2014 | 06:24 AM
Doomah's Avatar
Luddie did you use the moog cc507 springs? and if so what shocks did you go with if you have pick ones already.
Old May 17, 2014 | 09:16 AM
luddie's Avatar
That was the # for the springs, they REALLY lifted the car though, maybe a little too high. I put the air shocks back on and I had to buy extensions because they were bottoming out. In the near future I am going to put gas shocks on, I think I'll be able to get the standard shock because of the three inch spacer that I had to install.
Old May 17, 2014 | 01:09 PM
Station wagon springs lifted mine a good 2.5 inches over stock. I had 2 mounting holes for the bottom shock mount I just used the upper 1 which was about 2 inches higher.
Old May 23, 2014 | 09:19 AM
s i 442's Avatar
Oldsmobile enthusiast
Maybe if the rear is too high you could put the air shocks on up side down and air them up to lower the car?
72Cutlass
Apr 16, 2008 07:48 AM
Pghstarsky
Jan 18, 2008 04:21 AM
mojorison
Jul 11, 2007 04:44 PM
aristellier
Dec 19, 2006 03:51 PM
J'ville
Aug 19, 2006 01:07 PM
