Removal of valve cover
Old Sep 27, 2024 | 05:54 PM
JesseOldsGuy's Avatar
Does anyone have a work around? I need to switch the gaskets for the valve covers. Passenger side is done. Driver side next. Do I really need to remove the brackets holding the power steering pump? I don’t see any way around it. The back bracket has two studs at right angles to each other which prevent the back bracket from moving out of the way of the valve cover. See attached photos. So, I think that means that I have to remove the front bracket. I also don’t see how to loosen the steering pump fan belt. Sure, I could be blind, but I am scratching my head on this one.
Old Sep 28, 2024 | 06:55 AM
Stop scratching and just unbolt the pump first.
Old Sep 28, 2024 | 07:58 AM
Joe- I was thinking about that too. I was wondering if the bolts in the pump would hit the pulley as they were removed. Guess doing it would tell me pretty quickly. But, common sense now tells me that they won’t as it doesn’t make sense that the pulley would need to be removed. Thank you for the assistance.
Old Sep 28, 2024 | 10:22 AM
It's easier to just pull the whole front bracket and pump off of the motor.
sgolds
May 15, 2023 10:10 AM
WackyTacky
May 28, 2016 07:55 PM
jmills
Site Help
Mar 7, 2014 05:20 AM
rcdynamic88
Jul 18, 2013 04:36 AM
mgue67
Apr 28, 2010 10:27 PM
