Rear disc brake conversion.
Old Mar 24, 2010 | 04:22 AM
WheaYat's Avatar
Hello again. Ok so gettin a rear end may be a bit harder than I thought. So I thought about doin a drum brake conversion for the rear. Couple questions if anyone would know.??? For a 71 olds cutlass with 10 bolt rear non posi.
First-? will the conversion make the rear end any wider? I can't afford that, for I have custom wheels and they close to rubbin as it is.
Second-? Will the emergency brake still work?
Third-? The conversion kits are for cars with staggered shocks or with out staggered shocks? What is the difference and how to tell.
Fourth?- will I have to get a different booster, master cylinder, and proportioning valve? I already changed all that over when I did the front conversion.
Thank u for any help here. Much appreciated. GodBless
Old Mar 24, 2010 | 06:04 AM
Supreme68's Avatar
interested as well... i plan on doing a 4 wheel disc conversion at the same time...
Old Mar 24, 2010 | 06:31 AM
Eddie Hansen's Avatar
x3
me too I did look at a few kits, but was worried about the stock 15 inch rallyes fitting.
Old Mar 24, 2010 | 06:42 AM
Do you mean a DISK brake conversion?
At most it might increase the width by a quarter inch or so, but probably not even that much. It depends on the thickness of the center section of the rotor that you use.
Depends on the calipers that you pick. Some have e-brake provisions, some don't. A factory style caliper (Firebird, Seville, Eldo) will have the e-brake in it. Aftermarket calipers typically do not.
Look under the back of your car. Also see my response to your other thread.
You will need a master cylinder for four wheel disk brakes. You cannot use a drum/disk M/C. Most people use the Corvette M/C. This will bolt to your existing power booster. You will need a different proportioning valve.
Old Mar 24, 2010 | 07:07 AM
Supreme68's Avatar
i know a lot of u guys are against ebay, but i saw this kit... is it total junk or is ok for the money??? i have no problem spending the extra $$$, just point me in the way of a good kit...
http://cgi.ebay.com/ebaymotors/67-72...Q5fAccessories
Old Mar 24, 2010 | 07:18 AM
WheaYat's Avatar
Thank you mr Joe ! For answering both threads. Now can I ask if u recommend anyone in particular for a kit? Some body spoke about "right stuff" but I couldn't find anything on them. Google kept bringin up an anime website.
Old Mar 24, 2010 | 07:29 AM
gearheads78's Avatar
car guy
Do you have bigger wheels? If so and you want bigger brakes Kore3 is the best bang for the buck for brake kits. The other option is do what I did and use C5/C6 front with LS1 rear that I sourced myself.
Old Mar 24, 2010 | 07:31 AM
Supreme68's Avatar
^^^link to kore3 kits?
Old Mar 24, 2010 | 07:35 AM
WheaYat's Avatar
yeah i have the 20" Boze Alloys in the back. problem i think i will have is, the wheels are fitted to the car already. if the disc conversion makes the rear end any wider i will have an issue.http://www.flickr.com/photos/30332343@N03/2841430649/
Old Mar 24, 2010 | 07:44 AM
oldzzy's Avatar
wait.... what....
http://www.kore3.com/products.php?cat=11
Old Mar 24, 2010 | 08:04 AM
WheaYat's Avatar
what are the chance of these conversion kits bolting right on with no machining issues?
Old Mar 24, 2010 | 08:15 AM
oldzzy's Avatar
wait.... what....
I am not positive, but i think you have to machine the axle hubs. Give Tobin a call at Kore3. He is the man when it comes to brakes. BTW nice looking car you have there. How did you lower it?
Old Mar 24, 2010 | 08:27 AM
66ninetyeightls's Avatar
Land Yacht Captain
Kore doesn't list any rear disk conversions for GM products yet.
Old Mar 24, 2010 | 08:30 AM
oldzzy's Avatar
wait.... what....
What? There are a few. Here's just an example.. http://www.kore3.com/proddetail.php?prod=10277-03
Old Mar 24, 2010 | 08:31 AM
Land Yacht Captain
Ahh then they need to organize their website better. If you click on Rear Brake Conversions for GM there is nothing there.
Old Mar 24, 2010 | 08:35 AM
oldzzy's Avatar
wait.... what....
When i click on GM brake kits it shows up for me.
Old Mar 24, 2010 | 08:38 AM
oldzzy's Avatar
wait.... what....
Ahhh.. i see what your saying. I just click on GM big brake kits on the home page.
Old Mar 24, 2010 | 08:40 AM
WheaYat's Avatar
Thank u oldzzy. I was just lookin at yours too. Very very nice! I just used eibach lowering springs. Lookin to put bags but it will be a while. How did u lower urs?
Old Mar 24, 2010 | 08:44 AM
Supreme68's Avatar
both of you guys have awesome cars... are theyre any other companies that sell full disc conversion kits???
Old Mar 24, 2010 | 08:45 AM
oldzzy's Avatar
wait.... what....
Mine isn't lowered yet, it's still just a shell on a rotisserie. I do have 2" lower springs for it though.
Old Mar 24, 2010 | 09:00 AM
WheaYat's Avatar
Oh I thought that was it in the avitar.
Ps thanks supreme!
Old Mar 24, 2010 | 09:09 AM
Supreme68's Avatar
so did i... no problem... i like the 2 tone paint and the lines you chose...
Old Mar 24, 2010 | 11:27 AM
car guy
You can't go wrong with Tobin but if you want to some a few $$ you can find take offs and just order the front mounting brackets from Tobin at Kore3. I set my car up with full manual brakes and I can just about put someone through the windshield if I wanted to.
Depending on the rear end you use the rear LS1 brakes are close to a bolt on. If you have an Olds rear you need to make some shims and need to get creative with the axle retention bracket. If its a Chevy rear its a 100% bolt on. Also by ordering a Lokar ebrake cable kit and ordered a 3rd rear cable and used it in front I was able to use the stock ebake pedal. It holds on a hill great even out of gear.
Old Mar 25, 2010 | 09:52 AM
WheaYat's Avatar
thanks u cats ! for all the help!
Mocephus
Oct 1, 2021 09:45 AM
Maverick
Brakes/Hydraulic Systems
Jun 26, 2013 08:21 AM
Mike Hateful
Oct 3, 2011 06:58 PM
ricardo
Jul 27, 2010 05:26 AM
nh4kidsdad
Feb 12, 2009 04:49 AM
