Rallye 350 Options
Rallye 350 Options
The Dealer Wholesale Order sheet for the Rallye 350 shows the W-37 rear axle housing being an option - has anyone ever found a documented Rallye 350 with the W-37 option?
The order sheet also notes that the G70-14 tires were optional with either Raised White Letters, or with White Walls - has anyone ever found a documented Rallye 350 with either of those options?
That sure would make that one rare Rallye 350. I've never seen, or heard of one, with a factory W-27 option. That would be as rare as a '72 H/O with the W-46 (W-30 engine) option, or possibly a '73 H/O with the W-46 (upgraded engine) option.
How do you keep up with all of the replies on your postings? You sure must be very busy.
An article in Hemmings posted that the W-27 was actually available late in the production run of Rallye 350's.. If you have an early built Rallye 350, I doubt it's original..
http://www.hemmings.com/mus/stories/...feature14.html
We have production figures of 351 W27 units through June, missing only a few weeks of July production with a calculated guess of 4 for July based on the previous months.
That 355 is low production any way you look at it. Of the 351, 31 went into F85s and 77 went into Cutlass S models. Unfortunately, it does not break down if they we W31 or W45 cars. Logically, one would believe that the majority would go into the W31 cars, as the W45 was a relatively mundane performance car.
The W27 was also listed as an option on the Cutlass Supreme, but the records show that none came with it.
August 22nd, 2019 08:45 AM
cal cleveland
June 5th, 2011 08:05 AM
