Plastic fenderwells
Plastic fenderwells
I am having trouble fitting my new plastic fenderwells on my 72. (Parts Place). The passenger side fits fairly well however the drivers side does not. It seems to need trimming along the outside of the wheelwell and the fender holes don't line up. Anyone had problems with these or others? Can I heat it with a heat gun and re-shape it to fit better?
Any help would be greatly appreciated.
Kevin
Kevin
Kevin
Kevin
Heat gun is a good idea, if it works? I used the wifes hair dryer to loosen up stiff rubber grommets in the trunk, worked great. Anything is possible.
I'd hesitate to get anywhere near those with a heat gun....once you hit the temp where anything is going to stretch it's a VERY FINE LINE b/n that and melting/distorting/bubbling/or burning the plastic.
You can't shrink them back either....so you better be very comfortable that you can control the heat and push on the right area(s) while maintaining just enough heat to keep the plastic at the "plastic" stage.
Thanks! I was at the point where it was the heat gun or it was taking a flying ride out into the snowbank! Anyways, I did'nt do either one. I got a response from a person on realoldspower that bought his from the parts place and had the same problem on the drivers side. He just trimmed his and punched holes where they were needed for the clips. I guess my daughter won't be getting that expensive sled after all!
Thanks again
Kevin
Thanks again
Kevin
$160 ...
I'm going to start grabbing these even if the fenders are hosed ...
I've run into buying A-Body parts that fit all BOP but they don't fit Olds, like the windshield washer nozzles and the hood seal...
There are two varieties. I had to use the sponge foam one for my '72, which took a while for me to figure out how to install (but was successful). The stiff rubber one would not let the hood close.
This was just a trial and error fit...
My washer nozzles came from Fusick and they fit fine- where did you get yours?
Just curious...
![Confused](https://classicoldsmobile.com/forums/images/smilies/confused.gif)
Now I did have a big issue with repro power window regulators for my '72...
What was the issue with your hood seal?
Just curious...![Confused](https://classicoldsmobile.com/forums/images/smilies/confused.gif)
Just curious...
I have a 70 442 and bought the inner fenders from "The parts place". These don't fit either. Bought a lot of parts from the parts place while it was in process of restoring, now that I'm putting it back together I am finding about half the parts I bought from them are wrong and don't fit. If your buying parts go to Fusick, Year One or OPG it might be a few dollars more but it will be correct and fit. Even InLine has much better quality.
