one more simple question
saw this on another forum
You could also use a distributor with a 5-pin module and replace the module with a 4-pin one. That would require plugging the extra hole in the housing where the connector for the knock sensor wiring used to be. Distributors using 7-pin modules can not be converted to non-computer controlled use since they do not have advance mechanisms (they use the computer to control the advance).
also ran across another web site and found out the part is a vacume switch that retards timming 5 or 10 degrees at wot to offset detination. it senses the vacume and grounds out and retards the timming . the rest of the wiring is as folows terminal c =neg side of coil,terminal b=positive side of coil, terminal r=ground through the switch (n.o.),h=green wire to trigger in dist,l=brown wire to trigger in dist.
