Oil Preference
The oil sounds good. The thing with using synthetic oil is that it has less surface tension. Which means that it could have a tendency to find leaks in an old school motor. Another choice would be Lucas hot rod oil, it too has high ZZDP. Mostly just personal choice.
It’s semi-synthetic. I guess it’s all good. Thank you!
Yeah, I'm not quite sure how that (the semi-synthetic thing) works. I would tend to go one way or the other -- I use Lucas Hot Rod oil (high ZDDP dinosaur juice) in my car. I change it so frequently that the advantages of synthetic are lost on me.
