Oil indicator-dipstick - 1967 Cutlass 330 5.4l
Old Oct 3, 2022 | 09:11 PM
1967cutlassHT's Avatar
I see the manual shows an oil dipstick length of 16-5/32" for a 330 ci - see attached PDF, the one i have is 17".
i don't find any 330 ci dipsticks on searches.
are there other engines that have the same dipstick, like a 1968 350 ci?
any suggestions on where to find one? except Ebay for $125.
File Type: pdf
Old Oct 4, 2022 | 05:32 AM
What I would do is fill the crankcase and filter with 4 qts of oil and fire the engine. Mark the level on your dipstick with a file. Add a 5th qt, let the oil settle and mark that level with a file on your dipstick.
Old Oct 4, 2022 | 05:50 AM
^^^This, but I'll just add that after firing the engine briefly, let it sit for 10-15 minutes to allow all the oil to drain back into the pan. Mark and repeat with a full five quarts.
Old Oct 4, 2022 | 06:04 AM
I may have a nos 330 one around somewhere, I'll need to look. What part number do you want?
Old Oct 4, 2022 | 01:24 PM
nicks1966's Avatar
indicator part numbers are
384999 330 w/o cruise control
397868 330 with cruise control
Old Oct 4, 2022 | 02:05 PM
As long as the tube and dipstick are a matched pair, does it really matter? Obviously a longer dipstick in a short tube would show full with less oil, going the other way would show full with too much oil.
Old Oct 4, 2022 | 05:43 PM
Great suggestion, thanks Eric.
Old Oct 4, 2022 | 05:44 PM
thaks again Nick
Old Oct 4, 2022 | 06:00 PM
Donolds's Avatar
Hi Koda,
I’m interested in a 384999 67 Olds dipstick if you still have it. Especially if NOS or in great shape Let me know cost.
Thank you,
Don
Old Oct 4, 2022 | 06:03 PM
Donolds's Avatar
That is if 1967cutlassHT doesn’t want it.
Old Oct 5, 2022 | 08:06 AM
Hey Donolds, you can have that dipstick if you want. i will check mine using the 4 qt then 5 qt oil change first.
Old Oct 5, 2022 | 08:27 AM
nicks1966's Avatar
Measured from the top ring on the indicator
Full is 13 3/4
Add is right between 14 7/8 & 14 15/16
Old Oct 5, 2022 | 10:45 AM
good info, thanks Nick
Old Oct 10, 2022 | 06:59 PM
Originally Posted by Donolds
Hi Koda,
Thank you,
Don
I need to find the damn thing first, I'll get back to you.
Old Oct 12, 2022 | 03:58 PM
Donolds's Avatar
Thank you!
brianbeez67
May 22, 2022 06:50 AM
Jautuori
Apr 12, 2022 04:39 PM
Holmberg02
Aug 2, 2015 02:48 PM
sdcarguy
Aug 22, 2012 11:39 AM
