Newbie, 70 cutlass question...
Old Apr 18, 2009 | 03:18 PM
AdrenalinSS's Avatar
I'm getting ready to buy a 1970 cutlass, and the shell on the body needs quite abit of work,. I had just found a 1972 olds 442 shell in descent condition. would I be able to switch out the shells? I'm just wondering if they would be compatible. thanks
Old Apr 18, 2009 | 03:24 PM
csstrux's Avatar
Yes, just make sure you can get a title to the shell. I believe there are some difference in the sheet metal, so not sure if you can use the front clip, and doors, but the shell will fit on the frame. others will chime in with more accurate info. I imagine if the shell is tough you will need a clip and doors as well anyhow.
Old Apr 18, 2009 | 03:42 PM
Eric Anderson's Avatar
Fenders and doors work, the hood, core support, grilles and front bumper are different.
Old Apr 18, 2009 | 06:30 PM
jensenracing77's Avatar
X2
Old Apr 18, 2009 | 06:37 PM
2blu442's Avatar
But if the 1970 nose is in good shape you can swap over the core support, hood, grills, headlight assemblies and bolt it on the 1972 body. I made the swap once putting the nose of a 1971 Cutlass S on a 1970 Cutlass Supreme.
John
Old Apr 18, 2009 | 06:45 PM
John
X2 also
Old Apr 18, 2009 | 06:57 PM
csstrux's Avatar
I knew something was different, but was not sure on specifics.
Old Apr 18, 2009 | 07:25 PM
If the 72 442 is in better shape, why not just build that one instead?
Old Apr 18, 2009 | 08:07 PM
Here are the cars. I've already bought the 1970 cutlass, I just have to pick it up.
Here is the link to the 70 cutlass I bought:
http://viewmorepics.myspace.com/inde...lbumId=2737043
Here is the link to the 72 442 shell: http://omaha.craigslist.org/pts/1087026857.html
That's what I'm workin with, I know it's quite abit to tackle, but that's fun part
Old Apr 18, 2009 | 08:59 PM
mugzilla's Avatar
is Fast Enough ...
One of the hardest thing to do is removing the emergency brake cable through the body(hose clamp and grease)...
I usually bolt chains to the seat belt holes to lift ...
Old Apr 19, 2009 | 07:48 AM
Oldsguy's Avatar
Past Administrator
Welcome to the site. It looks like you have quite a challenge ahead of you.
Old Apr 19, 2009 | 01:00 PM
442_Mustang's Avatar
The pic of the 70 is a 2 door post car. The other car is a 2 door hardtop car. There's some BS differences there. More than just sawpping the hardware . My buddy took a post car and made it a hardtop and the interior trim was different, the main part of the door shells was different and the door jambs were different as well as some smaller things. There's a lotta work involved to change that stuff plus there's extra reinforcements in the hardtop. I'd put the hardtop body on the frame and build from there. Get hardtop doors and try to use the 70 front clip.
There's my .02
Old Apr 19, 2009 | 01:16 PM
Thanks for everyones info. Once I actually get the car back to my house, I will be able to better determine what I will need to do. If I can save the 70 shell and not switch, I won't, I just happened to stumble upon it and just thinking about it. The 70 cutlass cost me $250 and is worth the gamble in my eyes. We'll see
Old Apr 19, 2009 | 06:40 PM
oldjunk's Avatar
bumper
Looks like the 72 has a 70 rear bumper on it.
usertroy
Dec 13, 2012 08:19 PM
Scottem
May 29, 2012 11:24 AM
marty
Site Help
Nov 30, 2009 06:08 PM
chaos
Mar 18, 2008 05:42 AM
Butcha
Jun 25, 2007 04:02 PM
