new guy with a cutlass
Old May 3, 2006 | 10:28 AM
twistedcutlass's Avatar
hi there,
i own a 70 cutlass supreme, but i am having a hard time decoding the body tags, i cannot find any information that has any of the codes from my body tag, i am also looking to find out if there is any way to determine what engine/tranny my car came with. it is a factory clutch car, but im not sure whether it came with a three or four speed. any help would be appreciated. thanks
TiwstedCutlass
Old May 4, 2006 | 11:40 AM
cutlass66's Avatar
I can decode the body tag if you post the information on it. As far as the factory engine and transmission, I don't have any information to tell if they are original. All I can do is decode the engine and transmission codes.
Old May 4, 2006 | 05:53 PM
body tag
ok here goes
ST 70 34257 BF 07778 BDY
TR 979 B8G 50 F PNT
03A 327871 230212
Thats whats there
let me know what you can decipher
thanks
Twistedcutlass
Old May 4, 2006 | 07:34 PM
gibbo69olds's Avatar
This is what I have for you:
The 70 after the ST means that it is a 1970
The next digit 3 = Oldsmobile
The next two 42 = Cutlass Supreme V8
The next two 57 = 2 door coupe
The B = that it was assembled in Baltimore, MD
The 07778 = the unit number
The 979 = the trim number. The 979 corresponds to a Saddle color for the seats as well as identifying them as bucket vinyl.
The B8G = the Seat type however i can not find a match for this
The 50 = your body color and the F means that it has a vinyl roof, if i am correct.
I am not sure what the last string of numbers means
Old May 4, 2006 | 08:45 PM
that information is somewhat helpful, however i already decoded the vin and some of you info is incorrect, this is a fremont, ca built car
the seat info is great to know
thanks
Twistedcutlass
Old May 15, 2006 | 07:05 AM
That isn't what the number would tell you. All I can give you is what the reference books tell me and the B means Baltimore, MD
Old May 15, 2006 | 08:19 PM
cutlass66's Avatar
The only thing that I can add is that the "03A" is the build date, which was the first week of March. And the car was indeed built in Fremont, CA. The body color "50" is labeled "Bamboo."
Old May 17, 2006 | 10:36 AM
Again from the research I did it says that it was built in baltimore. Only F85 versions were built in Fermont, CA. Check your VIN number, if the 2nd and 3rd digit are 31 or 32 then it is a F85 and then the 7th number would have to be a BF instead of B. I am guessing your VIN looks like this 342570B07778, there may be a 1 right after the B and then the 07778. If one of these is your VIN then it was built in Baltimore, MD. not Fermont, CA
Old May 19, 2006 | 06:54 PM
ssaltuc's Avatar
After the 57, the BF...in my book says Fremont.
Olds 88 Rocket
Vista Cruiser & Wagons
27
Jun 12, 2012 06:03 AM
major tom
Apr 18, 2012 01:01 PM
Olds 88 Rocket
Jul 27, 2010 10:18 PM
88fan
Apr 6, 2010 05:46 PM
jrblanke
Jan 27, 2008 10:12 AM
