Leaking trunk
Old Apr 20, 2014 | 01:48 PM
bwichman's Avatar
Leaking trunk
Hi, I have replaced the trunk seal on my 1970 Cutlass but it still leaks, not as bad as it did before though. Trunk closes correctly. Is there an adjustment ?
Thanks.
Old Apr 20, 2014 | 02:17 PM
Check the bottom corners of your rear window.
Old Apr 20, 2014 | 03:05 PM
jag1886's Avatar
You need to check everything in the trunk, I have a different year than you but I found the trunk seal leaked, the rear window leaked, one tail light leaked and there was a body seal that also leaked. So water can get in from many places.
Best thing to do is find someone you trust and get in the trunk with a flash light and have that someone run the garden hose around everything until you find the leak/leaks.
Old Apr 30, 2014 | 04:40 AM
Kevin45's Avatar
Put a thin layer of grease on your trunk seal, close it, and see if it completely transfers to the trunk. If it does, then get a bottle of water and pour it down on corner of your rear window, then do the opposite corner and check the trunk for any drips coming in. Pull your tail lights and put some sealer around the holes to the trunk. And lastly, pull your rear tires, and make sure that there are no small pinholes starting on the fender wells. A good way to do check the fender wells is wait until it is dark out, put a floodlight/trouble light shining into the fender wells, then look inside the trunk for any light coming through anywhere.
Old May 1, 2014 | 07:22 AM
mdd71's Avatar
In my case it was the tail lights. Replaced the seals no leaks
Old May 1, 2014 | 07:52 AM
hookem horns's Avatar
All good ideas and a light inside the trunk works well also. If water testing, work slowly from the lowest point (tail lights) to highest point (rear window).
Old May 1, 2014 | 08:48 AM
defiant1's Avatar
Thumbs down
Thanks.
Mine does the same thing. I put chamois towels in the trunk where the water drips to mitigate the issue.
I noticed the water enters the gap between trunk lid and rear window trim and follows the underside of the trunk lid until it deposits in the area on either side of the trunk latch (and of course anywhere else it may drip along the way.
Where did you purchase your trunk seal?
d1
Old May 1, 2014 | 10:52 AM
pcard's Avatar
70 Cutlass SX
I had a very small gap in the weld in the upper right corner. It let in a surprising amount of water. I paint the entire weld with rust paint, sealed it and then painted it.
Old May 3, 2014 | 03:49 PM
bwichman's Avatar
d1
Fusicks.
Old May 3, 2014 | 04:22 PM
Sometimes you can persuade the trunk lip (body side) with a hammer and block of wood.
Dan Wirth
Oct 18, 2009 07:27 PM
DAN76
Mar 25, 2009 08:26 AM
tarps3
Brakes/Hydraulic Systems
Jun 29, 2008 04:18 PM
Margie's68
May 21, 2008 08:21 AM
dynamic88
Mar 6, 2008 09:58 AM
