Info on removing A/C from 72 cutlass...
Old Mar 16, 2008 | 11:07 PM
72Cutlass's Avatar
well since I had to dig into car anyways, I figured I would take advantage and take the a/c out. I read a thread on it earlier but I am unable to find it now. Can I use the set up from a none a/c car for heater blower and fab. some sheet metal to cover the hole that I would imagine would remain after switch?
Dave
Old Mar 17, 2008 | 07:54 AM
Dave
The easiest way to delete the A/C but retain the heater is to buy one of the aftermarket A/C delete heater boxes. This is a fiberglass part that replaces the A/C box on the engine side of the firewall and covers all the holes while providing a mounting for the fan motor.
Old Mar 17, 2008 | 08:41 AM
72Cutlass's Avatar
any idea's on who may sell the delete box?
I found this at yearone.com
http://www.yearone.com/serverfiles/f...ain2.asp?cat=3
is this what your talking about?
thanks
Old Mar 17, 2008 | 08:57 AM
74 Omega's Avatar
Hey Dave,
I got mine at
http://www.a/cdelete.com
pretty simple to install and looks like it was ment to be there. The best is you can also put it back to stock if you would like.
Old Mar 17, 2008 | 11:03 AM
72Cutlass's Avatar
on a side note, anyone have an idea on what the value of a A/C unit would be? I would like to sell it as I dont like to keep stuff I wont be using, so would like to have an idea on what fair. As far as condition, not really sure was not hooked up when I purchased car.
Old Mar 17, 2008 | 11:14 AM
74 Omega's Avatar
Originally Posted by 74 Omega
Hey Dave,
I got mine at
I meant "meant"
Old Mar 17, 2008 | 01:59 PM
72Cutlass's Avatar
has anyone done a delete without buying a $150 delete kit? I like the look of the one you used, but to be honest I hate to spend that kind of cash just to take out the a/c. I dont mind doing some custom fab to cover the hole but would using a non a/c box work if I made my own box to cover the hole? And I dont need to replace anything other than the box right? The fan for heater will work?
thanks again
Old Mar 17, 2008 | 02:24 PM
74 Omega's Avatar
At first I got a heater box from a non A/C Omega but it was a different shape and it would not line up correctly. It was not big enough to cover the fan area and vent area where the heater core is. I suppose I could have taken the dash apart and installed the non A/C box from both sides(correctly) but for $150 this was easier. Also on my car the heater core area protrudes into the engine bay so a flat peice would not cover it.
Old Mar 17, 2008 | 02:25 PM
74 Omega's Avatar
And yes, you do use your fan with the kit
Old Mar 17, 2008 | 10:23 PM
72Cutlass's Avatar
well thanks for the help on this guys, I decide to follow your lead and bought the cover from acdelete.com
Dave
blowitup
Jun 10, 2014 12:05 PM
sx455raidercelticfan
Aug 1, 2010 08:03 PM
viper771
May 31, 2010 12:40 PM
RWB
Dec 10, 2007 04:58 AM
4EYED
Sep 22, 2007 10:33 PM
