Ignition switch for tilt column adjustment
Old Oct 24, 2008 | 03:05 PM
7244too's Avatar
Question Ignition switch for tilt column adjustment
I am reassembling a tilt column for my 72 and everything has gone beautiful until re-installing the ignition switch. It seems like if I set everything as stated in the service manual the switch needs to slide roughly 1/4-1/2 inch closer to the bowl assembly to even engage with the screw holes to fasten it let alone allow me any adjustment on the rod. What am I doing wrong? The column went back together very nicely till this point. Has anybody else ever had this problem? Any help would be greatly appreciated. Thanks all.
Old Oct 24, 2008 | 05:23 PM
rocketraider's Avatar
Oldsdruid
Do you have it oriented the right way? and the correct switch for a tilt car? I ask because tilt and non-tilt switches are almost identical, except you flip it 180 degrees to make it work for the other application.
starfire
Dec 9, 2021 08:21 PM
Johnd
Feb 3, 2015 03:17 PM
jensenracing77
Nov 16, 2014 05:59 PM
ELECMAN
Jan 22, 2012 01:49 PM
ros6872
Feb 24, 2010 05:50 PM
