how to remove steeringwheel ?
Old Jul 12, 2007 | 01:20 PM
Oldsmofjord's Avatar
eyh !
wanna change the steeringwheel of my Cutty-81 but I'm at a dead end after dismantling the hubcap and nut. Do I need a special tool for the removal itself?
Old Jul 12, 2007 | 01:32 PM
Originally Posted by Oldsmofjord
eyh !
It's called a steering wheel puller. Either buy or rent one.
Old Dec 28, 2007 | 08:36 PM
Topless72's Avatar
Old Trick
When I was young and broke, I used to bear hug the wheels under the spokes and rock left to right and right to left while pulling upward... It worked 9 out of 10 times... the cars were younger then too though!
Old Dec 29, 2007 | 05:09 AM
Check it out!
http://www.jcwhitney.com/webapp/wcs/...atalogId=10101
Old Dec 29, 2007 | 09:03 AM
kevinkpk's Avatar
If your like me, now that you're old and broke you buy a steering wheel puller......
Old Dec 29, 2007 | 09:09 AM
kevinkpk's Avatar
Originally Posted by Olds64
That puller looks heavier duty than the one I bought last summer, thats a good price.
Old Dec 30, 2007 | 05:53 AM
Like Joe said you can always rent one at your local auto parts store. At least you can here in the US. Unfotunately, sometimes the steering wheel pullers are missing the bolts you need to get the steering wheel off.
Old Dec 30, 2007 | 07:14 AM
Topless72's Avatar
Strangely enough I pulled mine last night to replace the key cylinder. I tried the bear hug routine and then broke down and got my puller... The puller worked in a heartbeat.
I used the same one I use to pull harmonic balancers with because it has a variety of slots.
Old Jan 9, 2008 | 06:01 AM
New'n72's Avatar
Not to high jack this thread but since you mentioned "key cylinder", I have fought that for hours without success. What do you use to push in and depress the catch?
I pulled the steering wheel and and went by the book (as far as the book goes) as for as position of the key and depressing the release. I tried with a little screw driver, and a pick, an orange stick, and a few things I don't remember right now.
I could not get the cylinder out.
Old Jan 9, 2008 | 04:01 PM
Be sure you are pressing in the correct place. If the cylinder has never been removed before, there may be a thin layer of casting flash covering the slot. See the attached photo. The slot is inside the circled area. Note that the key buzzer switch with the two metal contacts that cover the slot needs to be pulled out first.
Oldsragger
Jan 31, 2015 11:32 AM
KRICHEN922
Jul 1, 2010 09:17 AM
jwavanlaarhoven
Nov 6, 2009 04:30 PM
mark5
Feb 18, 2006 04:29 AM
jim braith
Jan 2, 2005 05:48 PM
