Hood trim removal??
Old Aug 20, 2016 | 05:39 AM
Almond900's Avatar
Hood trim removal??
Is there a good way to remove the stainless trim on the back edge of the hood by the windshield? I'm looking and I do not see any fastener's
Old Aug 20, 2016 | 06:19 AM
Almond900's Avatar
I figured it out, since there were no fastener's, I decided to try a piece of wood and a hammer, patience and working back and forth and she popped off with no damage
Old Aug 20, 2016 | 07:32 AM
rcorrigan5's Avatar
Randy C.
The same method works when putting it back together, too. The key word - patience! I found I had to be a bit "stronger" in putting it back on, but it eventually went on like it should!
Randy C.
Old Aug 20, 2016 | 07:56 PM
70Post's Avatar
Before you reinstall it look CLOSELY at the underside of the hood where the trim covered up the underside skin....you should see a few "retention" bumps in the underside hood skin. These are what put up the most resistance when removing/reinstalling the stainless trim piece...the trim has to spread open as you push it back on to get over these bumped areas.
Old Aug 20, 2016 | 08:00 PM
Almond900's Avatar
Thanks for the tips, hopefully I will be installing the trim Tuesday, i'll be shooting paint tomorrow and reassembling then
pencetaylor
Nov 13, 2015 10:43 AM
bainer1290
Oct 29, 2015 07:39 PM
georgiaboy697
Jul 2, 2010 09:23 PM
f-85
Dec 6, 2008 01:39 PM
mikeraines63
Jul 4, 2008 03:23 PM
