Here's my Olds Cutlass. Any ideas how to improve ?
Old Jun 18, 2007 | 11:09 AM
Oldsmofjord's Avatar
Hi !
finally found a site where there's some ACTION.
Attached is a pic of my Cutty LS sedan with a tender V6. It's got 110 hp I think (not 100% sure but the dealer believed so)
It's a 1981 and in pretty good shape.
However, I feel that it can offer more than meets the eye. I was thinking of what I can do to improve the engine or carb, ignition system, coil or alternators.....
Any ideas or thoughts are most welcome !
Old Jun 19, 2007 | 10:16 AM
Redog's Avatar
I don't know if they make too much for the V6, but you could try looking at www.summitracing.com and see what they have
Old Jun 22, 2007 | 12:48 AM
would you recommend a new MSD ignition system ?
Old Jun 22, 2007 | 04:59 AM
Oldsguy's Avatar
Past Administrator
If your car runs now, I wouldn't recommend it. Your existing HEI probably works just as well. People like to use ignition upgrades (like MSD) on engines that have been built up and orginally had points style ignition but like I said, you car already has HEI.
Old Jun 22, 2007 | 11:22 PM
88 coupe's Avatar
Junior Member
Doesn't matter whether you use points or HEI. MSD will not give you any increase in power.
However, as an under hood dress up item, I understand it is well worth the money.
Norm
Old Jun 25, 2007 | 09:05 AM
After just idling 5 mins, and I rev the engine some times....the engine is really too hot , why is this ? Is there a leak somewhere ?
I could swear I smelled some exhaust in the engine compartment (Im not familiar with what should smell and what not....
Old Jun 26, 2007 | 06:18 PM
Jim's rare 80's Avatar
Jim's rare 80
Hi. Hot engine is iether, low coolant, thermostat, or no fan shroud. Does it overheat when driving, or just sitting? Let us know. jim.
Old Jun 27, 2007 | 01:03 AM
HI
it hasn't overheated on me yet. It gets really hot after just a short drive. It might be normal but I really don't know for this type o' engine (V6, 231CID)
Old Jul 1, 2007 | 06:44 PM
marcar1993's Avatar
Well, if you smell exaust in the engine compartment, is your a.i.r. system functional/complete. If a hose is missing, then exaust will leak into the engine compartment.
Old Jul 25, 2007 | 06:23 AM
any ideas as to what rims I could put on here ?
Old Jul 25, 2007 | 12:36 PM
marcar1993's Avatar
There are some factory rims that look good. The olds SSII and SSIII look good on g-bodys.
As a thought, If you can find one, a turbo regal/GN engine should drop right in, seeing how it's the same block, and it's in the same body style car.
Old Jul 25, 2007 | 09:03 PM
79OLDSXTC's Avatar
you wanted to know how you can improve your engine and you say its a 231
did you know the buick grand national and GNX use that motor. if there is one your junk yard start swapping parts especially the heads hell the whole motor if you can and don't worry about your rims just yet you'll get more enjoyment out of your car if you spend the money to make it go than if you make it show besides it looks like you have the makings of a wicked sleeper
Old Jul 26, 2007 | 01:21 AM
thanks for your thoughts
It is indeed the 231cid V6, and it kicks dust on the highway for sure
Dunno about switching engines is possible just yet, I mean the government wants a clue as to what Im doing with it - and a change in the engine compartment will leave me with loads of paperwork and I gotta show it to the certified workshop for approval (it sounds rediculous, and it is - but then again it's Norway we're talking about)
I'll stick to adding and/or removing smaller parts up front.
Right now Im looking at suspension
navvet
Suspension & Handling
15
Jul 7, 2014 04:09 PM
cjsdad
Jan 20, 2014 07:10 AM
bigoldscruiser
May 25, 2010 07:47 PM
alexrains
Feb 19, 2010 02:03 AM
t_visker
Sep 27, 2006 09:01 PM
