help with head gaskets
Old Sep 15, 2011 | 08:48 AM
bammer's Avatar
bammer
have 455 engine out of a 1970 tornado,needs head gasket replaced,have never attempted anything like that ,could anyone give me a step by step to accomplish the task,has edebrock aluminume heads,also intake,thnks
Old Sep 15, 2011 | 09:24 AM
MrLightning's Avatar
suggestions
Replacing head gaskets are not a biggie to do and only require that you make sure your mating surfaces of your heads and block are clean and burr free, and that your piston bore diameter in the gasket itself is slightly larger than the bore diameter of your block. I STRONGLY suggest if youd like the best head gasket that you can buy, that you buy COMETIC head gaskets. These head gaskets are pricey but, youll only ever have to buy one set, because they are reusable. Check them out.
John
smcurro
Feb 11, 2009 08:47 PM
Alkoh0liker
Jan 1, 2009 07:44 AM
Alkoh0liker
Jan 1, 2009 07:42 AM
deltathunder
Jul 21, 2008 08:10 PM
Deltarocket
Jun 5, 2007 06:54 AM
