Headlights
Old Oct 20, 2018 | 12:05 PM
jhawkthebeast's Avatar
Headlights
So i was leaving church last night and my headlights wouldnt come on i got pulled over twice and i almost hit a car. My iner dome light works and my back lights work. My front grille is open and. I dont have a front bumper and its been raining constantly this whole week. Any reason this would happen? My lights sometimes do this. Let me know if theres anything i can do
Old Oct 20, 2018 | 12:07 PM
72455442RA's Avatar
the dimmer switch could be faulty
what year and model Olds ??
Old Oct 20, 2018 | 12:13 PM
The dimmer works I think cuz the inner gage and stuff goes from dark to light by turning it to the left and my inner dome light comes on to. 72 cutlass 350 rocket
Old Oct 20, 2018 | 12:48 PM
Check for voltage at hi beam switch on the floor with the headlight switch pulled out.
Old Oct 20, 2018 | 12:51 PM
I don’t have hi beams because I hit a curb guard cuz I didn’t have a neutral safety switch and it was in drive, I have one now but I’ll still look for it.
Old Oct 20, 2018 | 01:00 PM
Also I looked under it and tbh I don’t know what is what only thing I know under there is the neutral safety switch and that’s cuz it was messing up. So what do I need to do exactly
Old Oct 20, 2018 | 01:09 PM
There is a switch on the floor, pull the carpet back so you can get to the plug. With the headlight switch on use a test light see if you have voltage on the blue wire, or... you can jumper from the blue wire to the pink wire.
Old Oct 20, 2018 | 01:19 PM
2blu442's Avatar
What year/model of car are you working on?
Old Oct 20, 2018 | 01:21 PM
Old Oct 20, 2018 | 01:37 PM
The carpet is imbedded to the floor it can’t be uprooted
Old Oct 20, 2018 | 01:54 PM
Your carpet is glued down??? Try taking off the side sill plate and wiggling the carpet loose from under the side kick panel. It should come up with not much effort. Where the dimmer switch is though, you should be able to remove the plastic trim piece just above the carpet and pull it down to expose the dimmer switch.
Old Oct 20, 2018 | 02:53 PM
2blu442's Avatar
Not sure how I missed that!
Old Oct 20, 2018 | 03:19 PM
Then you need to un-imbed it... Checking voltage at that switch will tell you which direction to go, forward or back.
MARTY2476
Apr 28, 2017 03:18 PM
miko442
Jun 29, 2016 07:33 PM
scott71
Jun 18, 2011 07:04 PM
smcurro
Mar 28, 2009 07:36 PM
sickbox
Nov 20, 2007 03:56 AM
