found a possible car to restore
Old Sep 2, 2018 | 05:57 AM
Dano58's Avatar
Question found a possible car to restore
I have found a 1971 cutlass, not a 442, in pieces with some rust on the quarter panels. This guy bought it from a kid who was going to restore it, but has not has the time. They have a 455 marine engine and 400 automatic transmission.That is out of frame. I'm from rural Montana. So competition for this car is not high, but there will be some. My question is What is this worth. I really don't know. What do you all think?
Old Sep 2, 2018 | 05:59 AM
Dano58's Avatar
Need to add it's a coupe.
Old Sep 2, 2018 | 06:04 AM
scrappie's Avatar
Need a bit more info like pictures of the car would be best. Factory options and overall condition of car will determine desirability and current value.
Old Sep 2, 2018 | 06:15 AM
Dano58's Avatar
To be honest I haven't seen it yet, wanted to have some idea when I meet the owner.
Old Sep 2, 2018 | 06:27 AM
RetroRanger's Avatar
72 Olds CS
Hmm hard to say, it doesn't look to bad in the pics, but the more complete car w the least rust is the best car to start with. That said check the floors, fenders, trunk and frame for rust. See if it has the trim pieces.
id guess maybe 1500-2500 w out actually looking at th car.
Old Sep 2, 2018 | 09:58 AM
stevengerard's Avatar
very tough to say, car looks solid, if they have all the parts then that helps. But I guarantee even if they say every part is there - its not. That looks like a lot of work but for the right price and if you re looking for a project if the body is pretty solid then a lot of the other parts can be had. Oldsmobiles are expensive to fix up the good thing is this being a Cutlass the market (for better or worse) doesn't put nearly the premium on it as 442s so you can get it cheaper and even build it as you wish instead of worrying about perfection or originality.
Old Sep 2, 2018 | 11:11 AM
It's a shell and a non runner. That takes its value down a lot. At least it's not being stored out in the elements. From the window stickers it looks like it was last tagged in 2005 - that's a long time to leave a car sitting. I'd suggest starting at $1200 and work from there. Do you know if the engine turns over or is seized? It's a 74+ engine as evidenced by the EGR valve. Interesting the oil pressure sender is 90° to the block. The rad support appears to be fairly intact; i don't see the battery side all rotted out. Where are all the other pieces that you'll need to finish it? That sound/heat insulation should not be on the firewall. Whoever installed that got it all wrong. Good luck with your decision. BTW, there are other cars around - this one doesn't have to force your decision to buy.
Old Sep 2, 2018 | 12:40 PM
I'd go with this also. Be prepared a lot of nickels and dimes will add up in getting this project finished.
Old Sep 2, 2018 | 01:49 PM
Those nickles and dimes add up to thousands of $$$$ FAST
Old Sep 2, 2018 | 08:55 PM
shiftbyear's Avatar
Bucket seats, console and sport wheel are worth a lot. Could be beauty in the right hands. Good luck
Old Sep 2, 2018 | 09:09 PM
Dano58's Avatar
Red face Thanks
I have read all your responses, and appreciate them. I'm guessing $2000 has always been my top, was thinking 1500 to start, but I will probably start a little lower now. This actually gives me some ammo to bring him down. Might go see it tuesday. If I get it I will be back on this forum looking for the parts its missing.
Thanks Again
Dan
Old Sep 2, 2018 | 09:21 PM
OLDSter Ralph's Avatar
Maybe try to get a feel for what he is thinking would be a fair price. He may want more than you are willing to pay. It may save you a trip to look at it. Another thing to think about is how you are going to get all those PIECES home...........how many trips would you have to make.
............Just my two cents worth
Old Sep 3, 2018 | 05:50 AM
edzolz's Avatar
Can't tell if all of the glass is there, but if not add more $$ to completion costs. Looks more like a #5 to me. Just really a good parts car.
Old Sep 3, 2018 | 08:08 AM
costpenn's Avatar
Like others have said, there is a lot missing on that car before even getting to possible rust issues. Getting it and all the parts home in itself will be a challenge to you and anyone else who owns it - I'd say 1200.00 tops.
Old Sep 3, 2018 | 09:22 PM
Dano58's Avatar
OK, so I went and saw it. Body is good not rust the one front fender would nad a patch welded in. But the pieces are everywhere, no way to tell how many small pieces are missing. Has a supposed rebuild 400 auto transmission, but the engine is in pieces, the cam and front cover are missing. all inside not rust, But.... interior is the same no idea what is there and what is missing, I would guess 85% there as a whole. He is talking $1500, I said no more than $1000. He is thinking as am I. On a separate note he has 1977 Firebird, 100% there all assembled running that he wants the same for. 350 engine and 350 transmission in it and running body straight no rust. I'm kicking around the idea of buying both and restoring the firebird and collect more parts for the Cutlass as I go. I think he might take $2500 for booth I know he would take $3000. I am wondering what a parts car is worth, is $1000 a reasonable number?
Dan
Old Sep 4, 2018 | 01:17 AM
Mossy's Avatar
Unless you have the time and money to take on 2 projects I’d spend that $3k on a more complete car.
Old Sep 4, 2018 | 07:17 AM
Walk away. It's not worth the hassle of moving it and then trying to list parts for who knows how long. When everything is apart and especially from someone else the headaches will never end.
If you like the screaming chicken, buy it and drive it.
Old Sep 27, 2018 | 03:39 PM
Cstoliker's Avatar
71 is the more desirable year. It was the last year of “muscle car” era before emissions standards started to suck the fun and power from cars. If restored, you could get away with a lot more.
Pluss with the bucket seats and steering wheel your already on your way to making it a 442 clone.
lshlsh2
Jul 8, 2025 03:35 PM
70chevelless
May 23, 2016 11:13 AM
bbolds442
Nov 29, 2013 08:20 PM
Bubbanym
Sep 29, 2012 06:15 PM
Ida Bee Gaming
Apr 29, 2012 07:16 AM
