floor shifter needed 72 cutlass supreme
Old Dec 22, 2011 | 03:01 PM
David Lidenberg's Avatar
Hi my automatic floor shifter for my 72 cutlass supreme broke off in the middle, so I now have to shift with a channel lock pliers, does anyone have one for sale? Everything else is ok just the cast piece that connects to the walnut **** and floor broke in half, thanks for your help.David
Old Dec 22, 2011 | 03:58 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Here is a pic from member 2blu442. https://classicoldsmobile.com/forums...s/2blu442.html . Hopefully he still has this part. I'd send him a message first.
Old Dec 22, 2011 | 04:11 PM
Chumley's Avatar
I was getting ready to sell one on ebay, but if you don't have one already I will sell you mine. I'll have to dig it out and determine a price, send you pictures, etc. Chumley
Old Dec 23, 2011 | 03:16 PM
thanks just let me know how much.
Old Dec 23, 2011 | 07:51 PM
70Post's Avatar
What's wrong with the adjustable jaw type shift handle?? It's chrome and has a cool look to it...sort of a Hurst Verti-Gate look. Made in USA and it won't break like those diecast chrome originals.
You can even run a strip of black pinstripe tape up one side if you want more of a factory look.
Merry Christmas
Old Dec 23, 2011 | 10:16 PM
Merry Christmas
Now thats funny,
Old Dec 26, 2011 | 09:54 AM
Chumley's Avatar
David, I have a handle by itself. Is that all you need? The part # on the handle is 396724. I believe they used the same part from 69-72. However the pressed in pin (see photo) that connects to the cable is only about 1" long. On other shifters I have seen, it is longer. Did you save the broken handle? If so you can swap the correct one. Also the handle is missing the spring retainer.(see photo) Again, you can use the one from your broken one. The chrome is not too bad as far as these parts go. There is some minor pitting, but not as bad as the few scratches it has. If your'e still interested I can try to get some better pictures up close. OR, I have a complete shifter with base and the longer shift cable pin (chrome on handle is comparable to the other handle). Let me know, and I'll PM you with price and additional pictures if you want. Thanks, Chumley
Old Dec 26, 2011 | 02:08 PM
It looks like the right one, I need to go check the part, my shifter broke right before the pin, which is 1 and 1/4 inches long.there is no part number on my shifter handle where is the number located ,
Old Dec 30, 2011 | 08:56 AM
Chumley's Avatar
David, I think I got it figured out. 70-72 shifters used the shorter pin(the one I have is 1 1/4" like you said) and 68-69 used the longer one. I have 2 bases but they are for 68-69. One of them has the bottom part of the handle still attached, which broke off as yours did, right above the pin. Apparently this is a weak spot in the handle. So the handle I have is the correct one if you still want it. Chumley
Old Dec 30, 2011 | 02:59 PM
yeah I will buy it from you, let me know what u need, thanks David
Old Dec 31, 2011 | 09:33 AM
Chumley's Avatar
David, I sent you a PM.
Old Jan 14, 2012 | 09:32 PM
the part is the one I needed thanks again.
75hurstoldsW-30
Mar 28, 2014 07:53 PM
Roflow75
Aug 16, 2013 01:50 PM
69CutlassAlex
Feb 9, 2012 05:26 AM
mryoung4815
Apr 14, 2009 02:13 AM
olds4life
Feb 27, 2009 08:54 PM
