Fan Drive for 68
Old Aug 6, 2017 | 04:52 PM
TheBigBlueBoat's Avatar
Fan Drive for 68
I took the car out for the first drive today and one problem of many was the fan. As soon as I left it was deafening like a class 8 truck. It's a 68 Cutlass wagon with a recent 455 swap. I checked it against OEM parts and it has the long water pump, 3 groove water pump pulley (5 3/4"), 3 groove crank damper (7 3/8"), all matching for A/C. The problem is with the 68 (presumably non-A/C) fixed fan it's remarkably noisy, as you'd expect being driven 30% over stock. What's the correct factory configuration for this? Clutched or a different fan? Are there any differences in clutches or any other parts that have to match?
Old Aug 6, 2017 | 05:17 PM
rcorrigan5's Avatar
Randy C.
I'll take a stab at this. I had a '70 GTO (non A/C) that came from the factory with a flex fan. It was just downright loud on the road over 30mph and I finally got tired of it. With that car, all I did was remove the direct fan drive and the 4-blade fan and install a fan clutch. I got a correct fan from a junkyard Pontiac for the fan clutch and it made all the difference in the world as far as reducing noise. It didn't lose anything in cooling, either.
I believe you are right (don't have my reference books with me) in that a bare-bones car (no A/C, no heavy duty cooling, no heavy duty radiator, etc.) came with a straight-drive 4-blade fan. I'm assuming your car has A/C and therefore your pulley set-up is something that would come with A/C or heavy duty cooling. But it should also have a clutch-fan set-up. I'm thinking you should be able to remove the straight-drive 4-blade fan assembly and install a fan clutch with the correct fan (Olds used a 6-blade clutch fan in '68 & '69) and I believe that it would work as well as reducing the noise level.
Does your wagon have a fan shroud? That could play into this as well. I'm just trying to draw this from memory but I believe the 4-blade straight-drive fan set-up didn't use a fan shroud, where as the clutch fan set-up does.
Randy C.
Old Aug 7, 2017 | 05:20 AM
It's got the 68 6-blade fan with a shroud. I guess I need to dig up a clutch and fan.
Anyone know if other GM products used a similar bolt pattern and fan size?
Old Aug 7, 2017 | 08:28 AM
rcorrigan5's Avatar
Randy C.
I'm thinking the 6-blade fan you have now, if it's the correct one, will also fit a fan clutch. I'd obtain a fan clutch first and see if it works out with your current fan. I got the fan clutch for my '68 from NAPA. It looks very similar to the correct style fan clutch used in '68.
Randy C.
Old Aug 7, 2017 | 09:21 AM
The stock 1968 non-A/C fan is a four blade fixed. The correct A/C setup for a big block should be a six blade 19" fan with a clutch. The fans designed to bolt to a clutch cannot be used in a fixed (non-clutch) application because the bolt pattern is different. The clutch bolts to the water pump, not the fan in that application. All Oldsmobile water pumps have the same four bolt pattern.
Bee Saint Louis
Apr 13, 2025 08:28 AM
convertible 63
May 9, 2018 06:10 AM
Olds98
Aug 6, 2010 05:02 AM
agtw31
Jun 23, 2009 01:39 PM
esisson
May 20, 2008 12:09 PM
