Exhaust Manifold Removal 72 Cutlass
Old Apr 30, 2020 | 01:24 PM
dream66's Avatar
Cory
Is it possible to remove the Exhaust Manifold on 72 Cutlass without raising the engine. Looks near impossible to get to the bolts near the crossmember.
Old Apr 30, 2020 | 02:31 PM
If your taking about the flange, yes with a long extension from the bottom. Sometimes a torch to heat the nuts is recommended.
Old Apr 30, 2020 | 02:59 PM
dream66's Avatar
Cory
The flange stud is where I screwed up. During flange gasket replacement ATTEMPT, I broke the outer flange stud. Tryin' to decide whether to attempt to drill the stud out from underneath or take the manifold off and do it on a bench.
Old Apr 30, 2020 | 07:06 PM
Unless you have exhaust leaks at the manifold/head you want to fix also, I’d suggest trying to remove the stud with the manifold installed. Chances are some bolts will break off in the head, adding to the headache.
Old May 1, 2020 | 05:32 AM
There is no "flange gasket" to replace on a 1972 Cutlass.
old442x3
Feb 16, 2018 11:55 AM
Mikep442
Apr 23, 2015 05:09 PM
FTolliver
Mar 28, 2014 08:12 AM
yankees
Sep 30, 2013 09:44 AM
jag70
Nov 26, 2012 05:52 PM
