exhaust headers
Contrary to what the header manufacturers say, there is absolutely no difference between the Supreme and any other Cutlass or 442 as far as headers are concerned. You WILL have problems with the brake distribution block on the frame - it will need to be relocated to the top of the frame rail. Also, some headers will not clear the column shift linkage, so be sure to research this before you buy. These are generic problems with headers in all Cutlii, not just Supremes.
ok! Thats what I thought.I've heard so many things but wasnt sure.I was given some dynomax headers but they have o shaped flanges.I have to find some that are rectangle and I should be good. Thank you!
