Emission label/Cooling Label
Old Jan 1, 2009 | 04:21 PM
spherion1's Avatar
A silly question but I'll ask, does anyone know where the "Engine Cooling System" Label affixes? I found an original label for both cooling and emissions and found the specs for locating the emissions sticker. I have a 1971 Cutlass convertible with 350&A/C. I also notice the "Vehicle Emission Control Info" specs 91 Octane gas..I have been using regular and it runs good(only had the car 8 months)... am I screwing up ? Thanks for any assist.
Old Jan 1, 2009 | 05:14 PM
88 coupe's Avatar
Junior Member
Set the timing to 12° at 1100 RPM with the vacuum advance disconnected. If it still runs good, enjoy it. If it needs 91, it will let you know.
I'm guessing that with the proper ignition timing and 91 octane, it will run better.
Norm
Old Jan 1, 2009 | 09:45 PM
I have a cooling system decal on my 72. It's on the next level up (still center of the rad top plate above the emissions decal). I also have a coolant temp decal (like the ones GM dealers installed) on the left side of the rad top plate. Replacement emission and cooling decals are easily available at Dr. Decal for reasonable prices. Quality is excellent.
As far as the 91 octane, I asked that question too. The answer was that back in the 70's the Research Octane rating system was calculated slightly different than today. The 91 octane stated in the owners manual for your car is the equivalent of todays 87 octane. You're not screwing it up, in fact Olds states in the owners manual that the use of unleaded fuel is fully acceptable as long as it meets octane ratings. I don't think I would try running any of the E85 though. I find that a tank of mid grade (todays 89 or so) octane once in a while doesn't make a whole lot of difference in performance, since the car's tuned using 87 octane, it just costs more.
Old Jan 2, 2009 | 07:06 AM
spherion1's Avatar
Allan R,Thanks for the pic, that makes it easy! I thought the old gas was rated differently, thanks for confirming it for me. It runs great on today's 87 octane
Old Jan 2, 2009 | 07:07 AM
spherion1's Avatar
88 Coupe, thanks also for the insight, I think I will saty as is until and if I have a problem, Thanks again!
Old Jun 21, 2012 | 05:39 AM
jnssctt's Avatar
1973 Cutlass Sedan
Looking for Emission Control INformation / Vacuum Hose Routing label for my 1973 Cutlass Colonnade. Says part # 413597. Searched everywhere with no luck.
Old Jun 21, 2012 | 07:24 AM
Mike77's Avatar
Dr. Decal. Fusicks, Parts place.
HitTheHole
Sep 6, 2014 04:17 AM
pcard
Mar 19, 2013 08:29 PM
67 delmont conv.
Jul 2, 2011 10:18 PM
KZ442
Mar 15, 2010 09:24 PM
christine fury
Apr 16, 2009 12:57 PM
