duct switching
Old Dec 14, 2008 | 08:46 PM
cutty's Avatar
duct switching
what controls the ducts to be switched in the car for heat... there is only vacuum in 2 lines red.. purple.
Old Dec 15, 2008 | 04:26 AM
The air doors in the plenum are controlled by vacuum and cables. The setup is different from year to year. The best bet is for you to get a Factory Service Manual. They should have the under dash vacuum diagrams.
Old Dec 15, 2008 | 09:25 PM
cutty's Avatar
heat valves
you guys know if the valves can be replaced? or know any tricks for them to work
Old Dec 16, 2008 | 05:10 AM
Oldsguy's Avatar
Past Administrator
Air valves usually are a can with a diaphram connected to an arm. When they fail, the diaphram has split, cracked or otherwise won't respond to pressure differential. So, in a word no, they cannot be made to work. You will have to replace them if you are sure they aren't working. Make sure you have a good vacuum signal to them before doing so. You can even "steal" vacuum from a good manifold source, using a very long vacuum line and connect it directly onto the valve, it should actuate.
Old Dec 16, 2008 | 08:18 AM
Tell us what year an model of car and we might be able to give you a useful answer.
Old Dec 16, 2008 | 03:46 PM
cutty's Avatar
80 cutlass calais
Bernhard
Apr 27, 2013 10:54 PM
shopaholic07
Aug 4, 2009 08:19 AM
442scotty
Sep 16, 2008 04:54 PM
geckonz08
Aug 7, 2008 07:33 PM
nice72
Apr 7, 2008 06:26 AM
