Does anyone make a reproduction speedometer for a 71 Cutlass floor shift
Old Jun 11, 2011 | 01:03 PM
indianabanana's Avatar
The speedometer on my 71 Cutlass supreme convert with floor shift has been acting up. At the 1 mile odometer rollover it would stick for a while then clear. At the 10 mile rollover it would stick longer and then clear. Now it is stuck on the 100 mile rollover and will not clear. Needle jumps back and forth about 10 mile/hr.
Can it be cleaned/lubed? Does any one make a reproduction for the speedometer. I've upgraded to a 700R4 with the 455 upgrade so I can go electric or mechanical, but can't find a reproduction.
Has anyone swapped the guts for an electronic and still have it look original?
Thanks,
Jay
Old Jun 11, 2011 | 01:22 PM
Thanks,
Jay
Classic Instruments (among others) does conversions like that. Expect to lay out SERIOUS cash, however.
To your original questions, yes it is possible to disassemble the speedo, clean it, and lube if needed. The odometer roll has thin, fragile tabs that stick out between each of the number wheels. These tabs fit into notches to prevent the wheels from rotating all the time. Be VERY careful when disassembling as the tabs break very easily. This is intentional to thwart odometer tampering.
Old Jun 11, 2011 | 03:06 PM
oldspackrat's Avatar
Or, I can supply a floor shift speedo to you. Pm me if interested.
Old Jun 13, 2011 | 07:40 PM
Chumley's Avatar
I see floor shift speedometers quite frequently on Ebay.
BeenThere
Mar 14, 2014 01:55 PM
BeenThere
Mar 3, 2014 11:37 AM
outlawspeeder
Brakes/Hydraulic Systems
Apr 3, 2013 11:44 AM
j_link
Feb 23, 2013 11:16 AM
69442
Oct 12, 2010 05:50 AM
