differences between 70 and 71 doors??
Old Jan 23, 2013 | 07:25 PM
MBrown's Avatar
I have one door on the pass side of my car that has rust in the frt upper corner inside. I found a good 1970 door, will it fit the 1971 car?? Any differences??
Old Jan 24, 2013 | 05:46 AM
1970cs's Avatar
Lansing built
I had to look at your prior posts to find out that you have a 71 2dr hardtop
as long as it's post car to post or holiday to holiday.
Pat
Old Jan 24, 2013 | 06:31 AM
MBrown's Avatar
Sorry Pat, I should have specified it is for a hardtop. No posts so I should be good to go?
Old Jan 24, 2013 | 06:37 AM
507OLDS's Avatar
You are usually good to swap doors.If the 70 door had a 70 sport mirror,then it will have different openings in the door for the mirror,compared to 71-72.The only other thing to check is to see if the donor door has the same glass as your car,either clear or tinted.If it is different,then you will need to reuse your glass.
yamahondarider
Nov 26, 2014 04:51 AM
98regency
May 15, 2014 02:31 PM
66Dynamic
Apr 17, 2014 04:52 PM
83 delta 88
Jun 18, 2010 06:05 PM
64 Cutlass
Jan 22, 2010 06:59 AM
