Dash installation
Old Jun 9, 2009 | 05:16 PM
hinz57's Avatar
Dash installation
I am about to reinstall my dash on a 72 Cutlass Supreme and need some advice on method of operation. I've changed the color from Saddle to Black and I need to know from someone who has actually done this procedure. Is it best to mount the bezel first onto the dash and make all necessary connections and then come in with the pad and vent system after. Or does it go smoother if you mount the bezel to the dash pad and install it all at once. I see pros and cons of each method and I'm not sure the best course to take. I would really appreciate any advice.
Thanks,
Chuck
Old Jun 9, 2009 | 05:23 PM
jensenracing77's Avatar
i think you will have to install the two as a unit together.
good luck with the install. this can be very dificult. just take your time.
Old Jun 9, 2009 | 05:25 PM
hinz57's Avatar
I forgot to mention, I do have an assembly manual, but still am unsure of best procedure.
Old Jun 9, 2009 | 06:14 PM
2blu442's Avatar
I've done it as a unit and felt it worked out well. Drop the steering column first, and if you have a friend who can help support the other end as you work the gauge pods in and line up the studs to the holes in the metal frame. My 2 cents, John
Old Jun 9, 2009 | 07:28 PM
Definitely put the two parts of the dash together first, then install as a unit.
Old Jun 14, 2009 | 09:05 AM
hinz57's Avatar
Good advice. Everything went fairly smooth. Thanks for the tip on lowering the steering wheel, much easier. The only real difficult screw to get in is the lower left on the Heater/AC control unit. The headlamp plug is a bear to replug in. With its odd shape and little room for your hands, get ready for a few scrapes.
dfire25
Jun 6, 2013 09:07 PM
Phillip Anderson
Dec 10, 2012 07:03 PM
2 door cut
May 14, 2007 07:52 AM
72RocketPower
Jun 30, 2006 01:36 PM
Chris L.
May 28, 2004 09:44 AM
