Convt same as hardtop door?
Old Jun 16, 2010 | 05:41 PM
motorholmes's Avatar
Question Convt same as hardtop door?
I'm looking for a pass side door for my 65 conv and wondered if you guys know if the hardtop door is the same? I realize the glass may be different or whatnot, but my door skin is whacked and I just need a straight one.
Old Jun 16, 2010 | 06:43 PM
compedgemarine's Avatar
I am assuming it is a cutlass? if so the Hollander book says that a 64-65 2 dr hardtop and convertible interchange the door less glass and vent frame. doesnt say what is different on the glass and vent window frame. hope that helps.
Old Jun 16, 2010 | 08:36 PM
Cool, thanks. Hopefully the assembly manual will give me an idea on how to switch out the glass and mechanicals
Old Jun 17, 2010 | 03:00 AM
Yellowstatue's Avatar
On a '68 convert the vent frame has an extra channel for the weather strip to seal on...other than that it is interchangeable with the hardtop...
Old Jun 17, 2010 | 08:09 PM
swapping the vent frame and glass is pretty easy and straight forward. if you have a service manual it will show how. if not I would recommend finding one for it if you plan on working on it. makes life lots easier.
Old Jun 18, 2010 | 07:00 PM
This "Assembly Manual" doesn't have squat in it. I'll have to get a service manual. Which one? Are you guys talking about the red book with the rocket emblem on the front?
Old Jun 19, 2010 | 03:13 AM
Would you believe I don't have a '65 Fisher Body Manual...sooo in the '66 Body by Fisher manual (blue cover) it has illustrations and complete breakdown of the hardware inside your door...pg 273 Whatever you do- do not remove the power window motor from the regulator--without locking it down with a nut and bolt...the coil spring is very powerfull...
oldspackrat
Jan 23, 2014 08:39 AM
Greg Rogers
Body work
Feb 5, 2013 08:46 PM
Tom442
Apr 17, 2012 01:08 PM
Tom442
Jul 23, 2011 05:46 PM
jeffreyalman
Jun 6, 2009 06:28 PM
