convertible top lift cylinders
Old May 18, 2013 | 06:59 AM
bigfun64mo's Avatar
One of my top lift cylinders is leaking. It obviously needs to be replaced. Should I replace both of them of just the one? My thought is if i replace one, I should replace both. Anyone ever had this issue?
Old May 18, 2013 | 07:10 AM
redoldsman's Avatar
Proud Viet Nam Veteran
I would probably do them both since they are the same age. Then again, the other one might work for several more years. It is kind of a crap shoot.
Old May 18, 2013 | 08:39 AM
texxas's Avatar
They should almost always be replaced in pairs if you want both sides of your top to go up and down at the same rate of speed. I've seen an old piston rod, slightly stickey, due to a pitted rod not deploy as fast as the new piston. Not a good thing for your top.
Old May 18, 2013 | 10:02 AM
redoldsman's Avatar
That is a very good point texxas. Most of the time we just think about leaks.
Mak
Mar 21, 2015 10:33 AM
allyolds68
Aug 21, 2013 07:45 PM
smit4425
Dec 30, 2012 03:20 PM
pap4805
Mar 5, 2010 07:37 AM
jensenracing77
May 1, 2009 02:35 PM
