Convertible Top Gap
Old May 21, 2011 | 10:17 PM
Toledobend's Avatar
Convertible Top Gap
There is a gap between the top and the glass. Is there a fix? If I push down hard on the top above the window, the glass almost fits in the channel.
Old May 22, 2011 | 09:21 AM
rcorrigan5's Avatar
Randy C.
You might have to look at/adjust the window regulator(s) or the upper stops so your window will meet the weatherstrip.
Randy C.
Old May 22, 2011 | 12:06 PM
Toledobend's Avatar
The windows look like they are working correctly. They are fitting into the channel in the windshield frame. It's the top thats bowed above the windows.
Old May 22, 2011 | 12:35 PM
rroth01's Avatar
From: Orion Township Michigan 30 Miles North of the Murder City
I have a 66 and just had the frame sandblasted and powdercoated for the new top.
I dont know if the the 66 and 70 are the same but at the first elbow from the header bow there is an adjusting screw ,2 total, one on each side.They are a small allen head screw.I adjusted my gap with those screws.
Ron
Old May 22, 2011 | 11:02 PM
Toledobend's Avatar
Thanks, I'll be checking this out
Old May 23, 2011 | 07:13 AM
Lady72nRob71's Avatar
Was the top replaced? If so, it may not have been adjusted right during installation. My car has the issue you mention and I found no way to fix it yet.
Old May 23, 2011 | 07:25 AM
Toledobend's Avatar
Yes, it was replaced before I bought it. I'll let you know if I find a solution.
Old May 23, 2011 | 07:37 AM
1970442's Avatar
Adjustment
The hooks on the latches adjust to pull top to winsheild and if it is elsewhere like on top of the door there is adjusments in the rear of the frame.
Old May 23, 2011 | 09:06 AM
Bayou Olds's Avatar
Frame could be bent. There are Bobos who tried putting tops down while running 20-30mph and bent all sorts of things...................
Old May 23, 2011 | 11:32 AM
I remember looking into this a while back. There are frame adjustment points on the frame but it has to be adjusted right before the top fabric is installed. After that, I saw no possible adjustments.
I hope I am wrong and someone posts a solution!
Old May 23, 2011 | 05:24 PM
1965cutlassragtop's Avatar
Dude, it's a convertible!! They leak, and there is a slim chance that a 35-45 year old convertible is gonna be 100% tight. I've used adhesive all-purpose window/door sealing strips to fill in gaps. I had to put a piece along the side of my rear windows so the door window would seal up to it. And there are little gaps above the vent window at the junction corners where the top, windshield frame, and door/vent window meet. Just gotta keep it in a garage or buy a water-proof cover. And be gentle with the hose when ur shining her up!! My top and frame assembly are new, and aftermarket isn't always perfect. Def try those window sealing strips I mentioned though. It's barely noticeable and very effective. Just keep the car as dry as possible!!
GoBigRed
Brakes/Hydraulic Systems
15
Oct 5, 2015 01:00 PM
cfair
Jun 30, 2012 10:07 AM
Bobac455
Aug 27, 2011 03:20 PM
Olds luvr
Dec 2, 2010 08:26 AM
66starfire
Jan 3, 2007 10:31 AM
