Changing the engine
Old Sep 29, 2009 | 05:37 PM
rguertin87's Avatar
Changing the engine
I have a 1971 Cutlass S with a 350 4 barrel. It has the 3 speed automatic transmission. Im looking to install a 455, the one that I am looking at has been dyno tested at 465 HP. What else would I need to change to make this work?
Old Sep 29, 2009 | 05:57 PM
svnt442's Avatar
Well it's a bolt in. Use the 350 mounts, get a set of headers for the 455 and drop it in. Use all of the accessory brackets, pulleys and water pump form/for the 350.
You may need to address the transmission as a TH 350 will need some beefing up to handle that much of a 455. It will last for a little while, but don't expect miracles from it.
Old Sep 29, 2009 | 08:13 PM
rguertin87's Avatar
thanks for the advice, already has headers so im set there. Im planning on throwing in a 200R4 eventually, but I'm curious if I can keep my rpms down... maybe... just maybe my TH 350 wont rip in half.
Old Sep 29, 2009 | 09:23 PM
redoldsman's Avatar
Proud Viet Nam Veteran
If the headers you have are on the 350, they will not work on the 455.
Old Sep 29, 2009 | 09:28 PM
svnt442's Avatar
350 and 455 headers are not interchangeable even thought the head flanges are the same. The taller deck height of the 455 make the 350 headers hit the side of the block, the steering shaft, dump into the floorboards......many issues that won't allow them to work.
Old Sep 30, 2009 | 06:16 AM
It might last a week or so but eventually that TH350 would be toast behing a built 455.
Old Sep 30, 2009 | 06:18 AM
With all due respect to the Land Yacht Comadore I respectfully disagree.
Old Sep 30, 2009 | 06:20 AM
That is fine.
Do you really think someone can stay out of the throttle with a built BBO in their car? I know I couldn't. I just started my engine a few weeks ago and have less than 100 miles on it and I have already been hot rodding around in it.
rocket9r8
Ninety-Eight
Mar 2, 2007 04:55 AM
tiparosa
Feb 25, 2007 09:47 AM
shaunr
Feb 19, 2007 09:08 PM
Richie
Feb 14, 2005 02:49 PM
martine
Oct 17, 2002 11:52 AM
