Can you identify this part?
Old August 12th, 2008, 06:09 PM
scott_442's Avatar
Found this part laying underneath my 72 Cutlass after replacing the fuel pump, water pump and alternator belt. Have no idea what it is or where it goes....I have reassembled the car and it seems to run fine so it's obviously not a critical piece but I would still like to put it back where it goes!! Can anybody id this mystery part? Thanks!!
scott_442 is offline
Old August 12th, 2008, 06:12 PM
scott_442's Avatar
Sorry for the blurry pics but I've got a cheap camera.
Old August 12th, 2008, 06:36 PM
Registered
Bluevista's Avatar
It's the dime you stop on, did you just do your brakes too? I found a rod bolt in my oil drain pan a couple of years ago and can't figure out where or what car it would of came from so I tossed it, ignorance is bliss. Hopefully that is a spacer for a bracket or the alternator, or it could be for nothing.
Allan
Bluevista is offline
Old August 12th, 2008, 07:40 PM
dan2286's Avatar
It looks like a spacer from one of the accessory brackets.
dan2286 is offline
Old August 12th, 2008, 09:56 PM
leadfoot067's Avatar
looks like a pilot bushing.goes in the back of the crank....is your car a stick?
leadfoot067 is offline
Old August 12th, 2008, 10:01 PM
67olds's Avatar
Pilot bushing
Sure looks like a pilot bushing to me.
67olds is offline
Old August 13th, 2008, 03:49 AM
scott_442's Avatar
car is an automatic.
Old August 13th, 2008, 05:37 AM
Lady72nRob71's Avatar
Looks like the spacer that goes between the lower-power steering bracket and the block. Mine "fell out" after I got everything apart, as the grime held it in longer.
Since you changed the water pump, you would have had to pull the steering pump also...
Lady72nRob71 is offline
Old August 13th, 2008, 06:18 AM
YOU ARE SCREWED! That is your muffler bearing. Take your car apart and put it back in right away before you blow the engine!
Olds64 is offline
Old August 15th, 2008, 03:44 AM
car nut farmer
71rocket's Avatar
LOL!
71rocket is offline
Old August 15th, 2008, 06:30 AM
olds68's Avatar
I definately agree with Rob. I've dropped and/or forgot to replace mine more times than I want to admit. Without it, some of your belt alignments may be off. The good news is that you can put it back without removing everything again.
Now, I have to go look for my muffler bearing...
olds68 is offline
Old August 15th, 2008, 07:17 AM
scott_442's Avatar
Well, I decided not to deal with it anymore and took the car up to my local GoodYear service center and told them I needed to have my muffler bearing reinstalled...they said they do that all the time and that was a common problem on these older cars. So, I feel better knowing things are back together the way they should be....just don't feel too good about spending the $275. Thanks to everyone for helping me identify the bearing!! Next time I'll be more careful.
Old August 15th, 2008, 09:39 AM
You can see the part in this picture, at the left of the steering pump pulley. http://www.flickr.com/photos/robsalbum/2575146067/
It fits between the rear lower pump bracket to block.
I wish I would have known it was the muffler bearing.
Looks like another project this weekend, grumble, grumble...
Old August 15th, 2008, 09:54 AM
Rob has nailed it.
joe_padavano is offline
Old August 15th, 2008, 10:47 AM
Senior Moment
Jokers69's Avatar
Is that a plain jane production muffler bearing, or a clone of a low production-special ordered-numbers matching-1 of 1-dealer installed-hypo racing muffler bearing?
Jokers69 is offline
Old August 15th, 2008, 03:06 PM
scott_442's Avatar
and the WINNER IS....!!!!!!!!
Yep, lower power steering pump bracket spacer. Positively identified in Figure 9-33 on page 9-21 of my 1971 Olds Service Manual and in the pic supplied in the previous message...Thanks to everyone for the info....and the humor .
Old August 15th, 2008, 04:50 PM
Redog's Avatar
^^ I thought only Civics had those
Redog is offline
Old August 15th, 2008, 05:56 PM
dan2286's Avatar
You only paid $275!! I had to pay like $350 for that a few months ago!
dan2286 is offline
Old August 15th, 2008, 08:40 PM
is Fast Enough ...
mugzilla's Avatar
My 442 came stock with no muffler ...
Just tuned pipes ...
mugzilla is offline
Old August 16th, 2008, 09:30 AM
citcapp's Avatar
My 57 Olds came with roller muffler bearings. Later years had the cheaper bronze bearings.
citcapp is offline
Old August 16th, 2008, 04:27 PM
Registered
Bluevista's Avatar
I don't think that's a spacer of any kind, who machines a spacer and drills a hole through it? unless I'm seeing things. The inside and outide chamfer is usually there because it fits over a shaft and/or in something, like a pilot bearing or bushing, or for a tool. I've seen tent parts with a wire bale through holes like that too though. On my car that bracket spacer isn't even the diameter of a dime and it's raw painted steel, probably made from steel tube stock. I think it's some sort of shaft bushing or a part for a floor jack. Does the car have dual exhaust? then I would say it's a left muffler bearing bushing disgronificator, can only use a left hand wrench on those.
Allan
Positiveray
June 18th, 2015 09:47 PM
JR_N_CHICAGO
January 15th, 2014 12:01 PM
Insom
February 22nd, 2011 04:44 PM
Nathan :)
January 11th, 2008 11:34 AM
V8Hotrod.com
May 24th, 2007 05:59 PM
Quick Reply: Can you identify this part?
